My last photos of the day start with this shot of the Speed Demon team hydraulic press. Danny Burrows (Blowfish driver) told me about when they had a big puff of air into the airbox and the sides ballooned out. So they found and fixed any tears and broken welds, and then - to squish the out-of-square box back into nice straight sides and edges -- well, here's the press they used:
What they did was lift the front of the gooseneck trailer and put a block of wood on the ground, which block then had the airbox pieces place on it. Then -- using the foot of the hydraulic trailer lifter-upper as the moving part of the anvil and they weight of the trailer as the solid block above the work piece -- they pushed the button to raise the trailer - which means the hyd. foot tried to move down. Instant on-site press. Not bad ingenuity, hey?
Here's the team's IT center. Ian Mann is in the back of the photo. He's THE team IT guy. Next to him is Betty Howard, George Poteet's sister. Betty is the administrator for all of George's cars -- keeps licensing and insuring and such issues under control. I didn't see the face of the guy sitting with his back to the camera. But notice, if you can see it, the dual computer screens, the base station CB and the base station VHF radios for SD team communications, and also the UHF receiver so they can hear the Cook Enterprises local FM. Does your team have this kind of a setup just for the electronics. Yes, Ian's specialty is knowing and fiddlin' with the various MoTeC units in the car. Handy guy to have around.
The rolling parts bench -- both new stuff, in the ARP drawers, and parts as they're removed from the car.
Next is an assortment of shots of the adventure to get to the tranny, loosed and remove it, and while that's going on -- start setting up the replacement. Speaking of the old unit -- I heard (afterwards, at the truck stop as we ate, that the old unit had issues, all right. Once on the parts bench it seems that turning the input shaft DID NOT generate a similar turning of the output when it should have. Not in neutral - more like broken. So I 'spect that by morning the new unit will be in the car and set up to run.
Here's a picture of the airbox that got trailerised:
Back to more of the removal of the Liberty 7-speed transmission that costs about three times what I made in my first job right out of college.
That's the SD team thrash photos. Note, as Ray also commented, that there's not much of a trouble getting in close for photos. Stay out of the way of the guys turning the wrenches, but don't expect them to kick you out of the area. It's wonderful to see such work going on so well and so teamfully (new word there, hey?)
Next post will be a few photos of the Rice Vigeant work so they can run in the morning, too.
