G'day ,I have drawn up a draft of rule changes for the DLRA bikes which mostly follow the SCTA 2005/2006 changes and I need your thoughts on this rule , which pertains to modified frame class .
7 F frames must be based on an OEM type frame or a production replacement having similar geometry
I have changed 'similar' to 'same ' geometry in our draft ,because of the ambiguity of 'similar' I figured that how I interpret similar may be not how others would , what are your thoughts on how to quantify similar ? eg. how much more or less rake would be considered similar ,to the OEM, 1/2 degree 1or 2 degrees , 5+ degrees ? how are you guys dealing with this rule or have you any problems with it ?
Gary
