Jack, not knowing what sort of intake manifold you have, I would try first to drill and tap (3/4 min in the end water runners of the intake manifold, or else do the same to the ends of the heads. I run a belt drive water pump, but a electric would work just as well. As I said earlier, I run from the radiator, to the pump, to the heads, to the tank, and back to the radiator. It has never gotten over 190 degrees on the long course...
