If you can't read and understand all that, you are not ready to be an engineer!
It is telling you exactly what I told you in the beginning, power and aero drag are interchangeable.
If you increase one, the other changes by an equal amount in the appropriate direction to go the same speed.
Increase drag force and power required to go the same speed goes up by the same amount.
reduce drag force and the power required to go the same speed drops by the same amount.
You have to be careful with on line calculators many of them use rule of thumb approximations that are "close enough" but not mathematically correct.
Larry
