If you get the chance to watch a rear facing camera on a Motogp machine going down the straight at 330 kph, it is surprising how much work the shock is doing, and the amount of distance the suspension travels.
I'm really not surprised bud... I know how hard the rear suspension works, that's why we ran adjustable shocks on the bike and the hack...
prob we found out on the salt is every time the back end hops just a hair the way our swingarms are set up the chain wants to wrap and
the motor and turbo wanna go and we start a slight wheel spin...once the top run of the chain tightens up again it wants to again pull the
swingarm up and we keep compounding the slip. This slip makes us have to back out slightly to get the tire planted again. A GP bike swingarm
tries to pull the tire through the pavement when power is put on... the HD is a lil backwards. Its all based on the swingarm pivot in relation to
the axle. The rigid rearend just helps to eliminate some of the poor design qualities in the factory chassis. Basically we either design a chassis
and build in anti squat like a modern race bike or we make it so the wheel can't change its distance and relation to the drive sprocket... for a
short 3mile run, making it rigid is a cheap and bearable solution... if we where road course guys then the chassis redesign would be a must...
good input once again, thanks
