Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Bonneville Salt Flats Discussion
Build Diaries
(Moderator:
1926 Model T XO/VFCC
« previous
next »
Pages:
1
2
3
4
5
6
7
8
Go Down
Author
Topic: 1926 Model T XO/VFCC (Read 61412 times)
swackerle
Re: 1926 Model T XO/VFCC
Reply #105 on:
June 24, 2014, 11:39:03 AM »
Got a few more things done last night. Started work on the fuel system and put on a shiny new methanol carb!
Sam Wackerle
Finallygotit
Reply #106 on:
June 24, 2014, 04:20:43 PM »
Subscribing
Dan
Tucson, AZ
swackerle
Reply #107 on:
July 13, 2014, 12:47:29 AM »
Lots of work to talk about. Finishing up the fuel system and also threw in an MSD ignition. It's now hooked up to the HEI distributor and I made a set of wires, though they aren't shown. Also the fuel system has a pressure regulator and goes all the way to the carb with a pressure gauge;
Also threw together a windshield. Hopefully this will get me through tech. I sandwiched lexan with the strips of metal. I couldn't find one solid sheet in the thickness I wanted so it's two pieces as you can see. Should I be worried?
Sam
Last Edit: July 13, 2014, 12:49:03 AM by swackerle
Buickguy3
Reply #108 on:
July 13, 2014, 08:46:37 AM »
Having worked in the glass business for a while, I know that when you stack two pieces of safety glass you can get some great double images in the sun. On the Salt in the morning you run right into the sun. Make sure that you check it out with various sun angles. Just sayin'.
Doug
[America]
Tman
Reply #109 on:
July 13, 2014, 12:14:02 PM »
Doug, he has two pieces side by side, not sandwiched.
swackerle
Reply #110 on:
July 14, 2014, 01:51:18 PM »
You are correct Tman, I also installed the original sun shield about the windshield so hopefully that will knock out any chance of glare.
Reply #111 on:
July 14, 2014, 04:44:15 PM »
That "sun shield" ought to be worth at least 10 MPH (minus, that is).
Throw some tint on the windshield, don't run before 9 A.M. How do the roadster guys do it?
Pages:
1
2
3
4
5
6
7
8
Go Up
« previous
next »
Landracing Forum
Build Diaries
(Moderator:
