It is not common knowledge but a tire designed for the street can benefit from a break
in period of running a few hundred miles before they are shaved and used for high speed.
The chunking failure is reduced by the shaving that removes a lot of the unsupported weight
of the tread rubber to the casing.
The bond from the tread and the casing is done in the mold but will work better if some heat
and flex cycles are put through it first.
They are substantially stronger than a green tire .
That is part of the reason a new tire might fail where an older one might not until it wears out.
You can start out with a better tire if you break it in as part of the preparation.
