Author Topic: Fuel vent rollover valve for streamliner bike advice please  (Read 7930 times)
Offline jdincau
Re: Fuel vent rollover valve for streamliner bike advice please
« Reply #15 on: January 13, 2012, 08:34:40 PM »
Ah I see. In non rollover conditions how does the liquid get into the loop?
Offline dw230
« Reply #16 on: January 13, 2012, 09:17:56 PM »
Fuel pump?
Offline jdincau
« Reply #17 on: January 13, 2012, 09:36:40 PM »
Into the vent line?
« Reply #18 on: January 13, 2012, 11:08:20 PM »
G force or slosh from gear changes
Offline dw230
« Reply #19 on: January 13, 2012, 11:38:11 PM »
Sorry Jim,
As soon as I hit send I knew I was wrong. Then I could not find the thread to correct.
Mi Culpa(?)
« Reply #20 on: January 13, 2012, 11:53:18 PM »
MERLOT   :roll:  :?
Offline jdincau
« Reply #21 on: January 13, 2012, 11:53:39 PM »
15 gallons in a 20 gallon tank and a powerglide, but I can see if the tank is full and using a clutch.
Offline dw230
« Reply #22 on: January 14, 2012, 12:05:14 AM »
Sorry Sparky,
On a diet - Chardonny tonight. Joanie out of town, I will have to replace bottles tomorrow.
Offline robfrey
    • carbinitelsr
« Reply #23 on: January 14, 2012, 12:16:57 AM »
I've used some one way check in fuel vent line valves that "crack" at 0.5 psi on applications with electric fuel pumps that have worked real well for us. They are available at mcmaster fairly cheap. Only problem is that do not vent both ways and we noticed a little tank pressure when we remove the cap for fill up. I don't know if this is a legal way of venting but our install was on high hp street rods so we didn't have to go thru tech.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline Old Scrambler
  • Going Fast - Slowly
« Reply #24 on: January 15, 2012, 08:58:44 PM »
I always wondered if John Crapper included a "P" trap in his original flush-fixture.
Offline Buickguy3
« Reply #25 on: January 15, 2012, 09:32:36 PM »
    I suspect that came shortly thereafter for obvious reasons.
     Doug :cheers: :cheers: :cheers:
                   [America]
