Go with hefty. Bridgeport type not bench model. Tree should be ok. Good used is better than wimpy new. Get as much tooling with it as you can. Tooling can soon add up to more than the cost of the machine. I bought a used Bridgeport variable speed with digitil read out and power table and some tooling for $3,000. This was from a private party. Also check Craigs list. I picked up a $2,000 rotary table american made for $200. There is a company around Reno Nv. I have delt with that has good prices on tooling both domestic & foriegn. The name is Enco and they are a mail order house. If you can't move the machine yourself a mover can get expensive. I tend lean toward big is better but for a larger dollar outlay a few hundred more its worth the one time deal. My plasma cutter will cut 7/8 not needed so but if I do its there.
Jack
