Did you ever notice that nobody from here goes faster down there than they do here? Maybe the length of the course doesn't really add any advantage.
Not even Al Teague.
I wonder why?
I always assumed if you had the hp that a longer course would mean bigger speeds. Tom Burkland has finally turned the light on in my head about how that doesn't always work. What I know now, and Tom or anybody jump in here if I don't have this quite right, is that every car has an aero drag that relates to that cars Cd, frontal area and speed. The drag increase dramatically as the speed goes up resulting in the often stated formula that it takes 8 times the hp to go twice as fast.
The solution seems easy, more HP. The problem is you need to get that HP to the ground through the tires. Now you are dealing with the traction available to you, which is dependent on the surface (salt or dirt in our case), the tire patch and the weight on the tire. Tom says "0.6 is the upper end of salt surface friction coefficients, which range all the way down to about 0.22 in wet years".
So you have the aero drag holding the car back and the HP trying to move it forward through the available traction conditions. Overcome the available traction and you are going to spin the tires and not go any faster no matter how long the course is. The only way to go faster is to put the power to the ground through more tires, like in Tom's 4 wheel drive streamliner; have better (less wet) salt conditions (and these can vary through the course of the day); cut down on the aero drag of the car; or as most people do, add weight to increase traction.
Over in Australia at the lower altitude the aero drag is going to go up, but I don't know what amount. If their salt offers more traction than ours that is a plus. Sounds like Ack Attack was having problems hooking up the tire to the salt, probably due to the fact it was under water a few days before.
On Tom's streamliner they are up against the available traction using only 52% throttle on their 450 mph run. Of course all I'm talking about here only deals when you are running a certain speed and can't go faster due to tire spin. It is really amazing to me now the speeds Al turned in only powering the rear tires in his streamliner!!
Above I just touched the surface of what Tom has related to me and if anyone is interested in more PM or EM me. I might also try and get it down on one of my web pages once I get it really straight in my head, if that is possible.
Had a lot of fun and tasted the best beer in the world-Coopers, which I think is brewed in Adelaide. That town also had about 3 girls to every guy. Interesting. RR
I'm married and an old man now, but my wife doesn't seem to mind me looking
On the salt the flies were so bad during the day we all had nets hanging from our hats. Great experience. RR
I was wondering about the flies this year after all the talk. I don't remember seeing anyone wearing nets in Jon's pictures. If the wind is up does it blow them away like it does the gnats here?
c ya, Sum
