Finished up the balancer mounting and shield.
Apparently 'most everything went together okay- all systems function and it fires right up. It purposely doesn't have engine cover nor belly pan mounted- for double-checking fasteners, etc. after some run time.
Not having run it unblown before, I'm in-the-dark with the fuel system. Extrapolating down from my unblown V8 experience to this four (half as many cylinders needs maybe half as much fuel?) would require about a 160 Hilborn pill (if no other fuel changes)! I doubt pills of that size range even exist, so I drilled a batch of spare pills up to .177". The pill holder and its plumbing start to be a flow restriction at those sizes, so it's a guessing game for now. I hope to get some dragstrip test runs in soon.
