Again, good looking results very nicely presented.
Having fitted the 4/5 mile data from the timing slip, it appears the simulation is a bit optimistic through the mid-range, and results in a pretty long half mile “push off”. This leads me to a couple of questions.
Is there any accounting for the surface coefficient of friction? If not, this might reduce some of the optimism in the early stages and approximate soft/slippery spots and lifting for wheelspin.
Can you “short-shift” in the simulation, as you most likely would in reality? That is, can the shift rpm’s be specified for the lower gears and then just let the simulation run?
(I would be dubious of the value of rolling resistance predicted for gravel. I think you will find that performance on the salt is governed more by the coefficient and wheel slip/growth than displacement of the roadbed).
All good comments and questions:
1 - I played with the push off distance and speed at push off - I need some actual data to figure out what is going on there. The simulator is optimistic by a considerable amount at 1/4 and mile 1. A lot of different things could be going on, e.g. our engine is not matching the power curve from others dyno results, the driver is taking some time to get settled in the early parts of the course. I don't know.
2 - I can short shift the simulation and see what happens, when I was playing with the shift points it didn't look to change things much.
I shift when the force in the next gear is larger than the force of gear I'm in. For this hp curve it is well past the 13.2k rpm hp peak. I'll try short shifting by 500 rpm at each gear and see what happens.
3 - coefficient of friction - I'm still thinking how to handle it. I've been reading some good papers on how the static and dynamic COF changes with speed/etc. for different surfaces. Gravel was interesting not for rolling resistance but for COF at various slip rates. I think salt might be somewhat similar to a well packed gravel road. I still need to find a team willing to show me their driven and undriven log data.
4 - for our car we don't think we are getting a lot of slip, low HP (~125), good weight on the rear tire, the tire shows very little in terms of looking like things are sliding and we don't hear it and the driver hasn't mentioned he feels anything like that.
5 - tire growth, I need to re-read the posts and see if I can assume the amount at the speed we are running, I assume the growth is equal to speed ^ 2. I mentioned this to T. Burkland and he didn't have data on our tire.
6 - rolling resistance - good question, right now assuming the rolling resistance is in the dyno values. There are some good papers on this as well, the rr might go down when the tire grows if contact patch gets smaller, rolling resistance is somewhat a function of the contact patch size and location.
Thanks for the comments.
