Author Topic: Class 'B' bbc engine for sale  (Read 2409 times)
Offline toclub
« on: March 30, 2013, 07:27:03 PM »
432 cu. in.  BBC  Standard 9.8" chevy block. Lightweight chevy 3.75" stroke crank, profiled and pendulum cut, Gerator oil pump, aluminum sheet metal pan, Eagle H-beam rods w/ L19 bolts and coated bearings, 4.280" 13.5 to 1 pistons w/ gas ports and zero gap rings, new Pro Comp belt drive, Latest Pro Comp alum heads, 105 cc chambers, 2.300" TIT. int valves, 1.88" S.S. exh valves, Jessel shaft rockers, R & M push rods, Crane .737" lift roller cam, Crane roller lifters, aluminum sheet metal valve covers, MSD crank trigger and Dist. w/ wires, complete Mcleod dual disc clutch and flywheel. Completely assembled and ready to run. Best parts money can buy. Three passes sense freshened up. Went 234 MPH at Bonneville 2012 in 5000 lb. door slammer on third pass. $5,500 obo  Delivery in So. Cal. can be arrainged. Engine is in Victorville, Ca.     Glen  760-241-5334
Offline toclub
Re: Class 'B' bbc engine for sale
« Reply #1 on: May 25, 2013, 01:59:23 PM »
This engine is still for sale. The best parts you buy.
Offline jh333
« Reply #2 on: May 25, 2013, 03:06:33 PM »
What does it run for carburation?
Offline toclub
« Reply #3 on: May 25, 2013, 07:16:41 PM »
We had EFI on it. You can run whatever you want to.
