hitz Posted: Mon May 29, 2006 5:32 am Post subject: busa injectors
Bow,
Good thread you've started . Lots of input.
Gaza 414,
Good idea on testing the injectors ourselves. I think I have most every thing to do the test on hand. Where did the 9 volt choice of battery come from? Why not 12 volt? Does the injector get hot when testing it? It will probably be late winter before I start on the throttle-bodies adaption. I seem to be a slow builder but it's been matching the cash flow on this project so far!!
Thanks again to all for your input.
Harv
The 9V is the std voltage that they operate at. Most electronics work at 5Volts
Looks like bbb that the gixxer set up doesnt run an airbox?
Wonder what he claims are the advantages of this setup?
