Could you use the borrowed manifold and have the new one shipped to its owner?
Possible, but I know that he's going to be doing some dyno work, and hopefully get his Mini out on the track before the end of the summer.
Dean, sorry for the whining. There are times that I think I could work on this thing 24/7 and not have it right. But what's frustrating is that next to the Small Block Chevy and the Small Block Ford, the A-series engine is among the most common engines in the world. They made it for 49 years, it has a racing history that predates either of the aforementioned engines, but do you think I can find a welded up piece of steel with 3 flanges on it in the United States?
I've got parts that work, but now that I KNOW they don't work as WELL, I'm loathe to settle, especially at this point in the game.
And maybe it won't be an issue - maybe I'll see it in 6 weeks, I'll put it in, and be done. Unfortunately, my past history with this type of product has been negative.
So tonight was "Serenity Prayer" night.
I changed the things I could.
After putting in the engine and transmission this last weekend, I pushed the car back into the spot, and I heard this "clunk, ka-klunk". Of course, the transmission was my first suspect - I just spent Winter putting that together, but further investigation uncovered an oversized screw on a fabricated plate I made to access the yolk in the driveshaft tunnel. It was too long and catching on the grease zerk on the universal joint.
I wasn't particularly happy with the plate I had originally made - it was made out of a snow shovel blade that had a nice contour that worked well with the transmission tunnel - but it was aluminum and cheesey, so I pounded out a steel piece. A few new
properly located holes, some fire block, and it cinched up really nice.
I also whipped up a nomex shift boot.
The tunnel is closed off from the factory on the bottom side. Makes for a nice, flat bottom, but there's a long column of air that is susceptible to the same fire potential as under the hood.
I need to treat that tunnel almost as if it were a firewall.
The more I thought about it, the less I liked the idea of an aluminum snow shovel.
Tell you what -- If you don't get it in time, I'll push you to the one fast enuf to beat the 22 MPH. At least you'll be showing progress.
First, he pushes my buttons - then he pushes my car.
Keep it up, Stan, and I'll make YOU drive the damned thing!
