Author Topic: USFRA T&T  (Read 3545 times)
Re: USFRA T&T
« Reply #15 on: May 20, 2023, 10:44:30 PM »
If it was a bit closer say 2000 miles closer I would be there for sure  :-)
Whatcha do Ron, is come out & run the T&T, leave your stuff at my place & fly home. Then fly back out for SW, only to find your roadster has sprouted a large KB 600.  :roll:
Re: USFRA T&T
« Reply #16 on: May 23, 2023, 02:12:13 PM »
The deadline is looming!! :?
Offline gnomenator
Re: USFRA T&T
« Reply #17 on: May 23, 2023, 05:08:59 PM »
Sid, I had suggested last month that USFRA post a tally so as to encourage 'hand-sitters' to get off the pot  :x-   do you have an idea where we are?
Re: USFRA T&T
« Reply #18 on: May 23, 2023, 07:39:12 PM »
Only 43 as of 5 minutes ago! :-(
Offline gnomenator
Re: USFRA T&T
« Reply #19 on: May 23, 2023, 09:13:00 PM »
 Thanks Kiwi ,  :-( :-( muutt
Re: USFRA T&T
« Reply #20 on: May 23, 2023, 09:18:08 PM »
Just sent in my 130 Club push truck entry....
See you there...  :cheers:
Offline salt27
Re: USFRA T&T
« Reply #21 on: May 24, 2023, 02:57:31 PM »
If you are actually going to run a push truck in the 130 club you will need a driveshaft hoop, H or higher rated tires, metal valve stems and caps, and a metal battery hold down.
Re: USFRA T&T
« Reply #22 on: May 25, 2023, 12:07:41 AM »
Don, drilled holes to mount the loop.... have a plan for the battery hold down...  haven't checked tires yet, valve stems are metal bolted in pressure readers, but they have a plastic cover.... I have pics of the metal internals and how they are bolted in... Will check with tech to make sure I'm within the park.
They need entries, I'll give 'em one....  :cheers:
Offline salt27
Re: USFRA T&T
« Reply #23 on: May 25, 2023, 01:58:34 AM »
Stainless, I didn't intend this to be directed toward you, I was attempting to just give a heads up to anyone thinking of doing this to prevent disappointment.
I'm hoping more people follow your lead.    :cheers:
Offline PorkPie
  • think fast.....always
Re: USFRA T&T
« Reply #24 on: May 25, 2023, 01:35:02 PM »
a little bit wet since last night
Re: USFRA T&T
« Reply #25 on: May 31, 2023, 04:11:54 PM »
Just got the word from Ellen, not enough entry's for the test and tune... it is cancelled...  :x  :x  :-(
Offline salt27
Re: USFRA T&T
« Reply #26 on: May 31, 2023, 08:29:57 PM »
Nuts
Re: USFRA T&T
« Reply #27 on: May 31, 2023, 09:56:25 PM »
Don, I spent most of yesterday looking for H rated tires for the push truck.... found them.... figured on waiting till they said it was on before ordering.... hey the truck is about ready for new tires anyway....
So I guess we all wait a little longer to see what the salt looks like...  :cheers:
Re: USFRA T&T
« Reply #28 on: May 31, 2023, 11:40:26 PM »
Nuts
I used an appropriate word with the same amount of letters that started with a capital F! :-(
Offline gnomenator
Re: USFRA T&T
« Reply #29 on: June 01, 2023, 02:03:00 PM »
As I said in another post-perhaps it was a bad weekend to plan it??? :-(
