Author Topic: Tubing Notchers and Benders??  (Read 43711 times)
Re: Tubing Notchers and Benders??
« Reply #45 on: November 24, 2008, 10:28:05 PM »
I'm going to try posting the pictures of the attachment on my Makita cut off saw.
Hey, it works!!! Scary.
« Last Edit: November 24, 2008, 10:29:53 PM by Peter Jack »
Offline Geo
« Reply #46 on: November 24, 2008, 10:46:51 PM »
Peter,
That's cool!  Does the one bolt hold it steady enough?  Or do you find you are holding the holder with one hand?
Can you post some photos of the bar holder off the saw.  Side and bottom shot please.
I use the cutoff saw to notch the tubing.  And I found set up is easy using a digital angle gauge.  Harbor Freight for $30.
http://www.virtualvillage.com/items/item.aspx?itemid=4670187&utm_source=baseusa&utm_medium=shopping&CAWELAID=190645045
Geo
« Reply #47 on: November 25, 2008, 01:38:08 AM »
One more picture might help. Usually I either use it on the floor and use one or more blocks the same height as the table or put it on a bench and use adjustable height stands to support the tube. The single pivot bolt doesn't show any tendency to move but I usually have my left hand on the tube to the left of the clamp while I'm operating the saw with the right hand.
« Reply #48 on: November 25, 2008, 09:01:10 AM »
Duhh---I have used some similar device---to build my headers---but used hose clamps and a small angle iron to hold exhaust tubing for a but weld---
Guys please post these in the HOW TO SECTION---in the future can we post there then make a reference to you post---these are things that can help us all----thanks
Offline Cajun Kid
« Reply #49 on: November 25, 2008, 10:29:10 AM »
PJ  what brand and size cut off saw is that ? (I am spent out on the shop build, but maybe my wife can get me at least a nice 8" vari speed grinder and cutoff saw for Christmas )
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Offline Ron Gibson
« Reply #50 on: November 25, 2008, 10:44:38 AM »
Out of my range but check out beaumontmetalworks.com belt sander for tubing notching. Don't know much about it but seemed very versatile . This was brought up on the Metalmeet site a while back.
Ron Gibson, Omaha NE
« Reply #51 on: November 25, 2008, 02:33:10 PM »
I would think one of the HF oscillating spindle sanders
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=95088
might make a good tool for dressing to fit.... Wait till it goes on sale to buy....  :wink:
« Reply #52 on: November 25, 2008, 04:49:01 PM »
That's a 14" Makita cut off saw Charles. Tube fitting is about all I ever do with it because I'm lucky enough to have an 11" liquid cooled cold cut saw to do most of my fabricating.
Offline 754
« Reply #53 on: May 23, 2009, 03:14:58 PM »
Good tips
, if you are handy and have a lathe, try this..
Rig up a V block & clamp on your toolpost, bottom of V should be on Centerline.
Mount your holesaw, flycutter, rotaBroach, etc in the chuck or better with taper adaptor to spindle.
Clamp tube in v block, adjust angle & clamp toolpost.. use handwheel of carriage to feed tube into cutter..
 I bet you never go back to the drill to notch after that..
« Reply #54 on: May 23, 2009, 04:17:02 PM »
lobucktools.com
« Reply #55 on: May 23, 2009, 04:23:41 PM »
Sorry to contradict you Glen but it's actually www.lowbucktools.com . I know because I've made the same mistake before. Dave's really good to deal with and his stuff works.
« Reply #56 on: May 23, 2009, 08:39:09 PM »
It's ok Pete, New computer and Vista learning curve.Thanks for the correction.
« Reply #57 on: May 23, 2009, 09:13:50 PM »
Glen:
Have you tried your new Vista computer on chat yet? Neither of mine will work. I spend Tuesday evenings on the MAC.
« Reply #58 on: May 23, 2009, 10:01:36 PM »
After I chop saw the tubing if I have a weird or hard to fit angle I will wrap a piece of paper around and tape it together to make a tube. Then slide the paper out over the end and start cutting with scissors till I get the fit just right. That gives you the pattern you need. Slip it over the tube you are going to fit and mark the pattern on the tube. Grind off to the pattern marks and it should fit the same as the paper did.
Thats a neat and simple idea whichever way you end up doing your mitres. We used a cut off saw,a flap disc for dressing  the cuts, rounding the points and taking that tiny bit out the inside before a little tap with a heavy hammer to get the fishmouth right.There is a little intuition , a lot of T&E and a few rejects.........always remember though that If you leave the shortest pieces to last then you're bound to have a bunch of pieces that are half done already(too short for what you made them for)on one end. :roll: :roll:
What I did learn though was that if you imagine the cuts are at 90 degrees to one another and their dividing line is perpendicular to the pipe you are joining to it's easier..........once you've set the angle of the clamp in the cut off saw you only need to rotate the pipe through 180 degrees to make the second cut.
That didn't sound as simple as I thought....................
« Reply #59 on: May 23, 2009, 10:07:51 PM »
Pete, trying to down load the plug ins right now.I.ll get it figured out
