In 2019 at World of Speed, I set a record, backed it up, and proceeded to inspection as required to be measured. After the engine was measured, they put a wire and lead (?) seal on it between the barrel and the cases, and recorded the info. I understood that I could go out and set another record, back it up, and not have to be re-measured if that seal was still intact. I could even pull the head and do a valve job, if I wanted to, and it would still be OK. I think I could even return for another SCTA event and not have to be torn down again, but I have yet to able to put that idea to task.
