Author Topic: How do I link 2 engines rotating in reverse?  (Read 15607 times)
Offline TheSteelMan23
« on: October 23, 2011, 12:44:23 PM »
I am designing a streamliner build with two Small Block Chevy motors. They will be sitting nose to nose in the center of the car and then each one will be linked to the corresponding front or rear differential. My question is how do I link the motors together to ensure that they are turning equal RPM's? Are there any available gearboxes that anyone knows about or maybe a belt drive? Or is this something that I am going to have to get custom machined? Any ideas?
I have two speeds... Fast, and "What the hell was that!"
Offline Captthundarr
  • In line
Re: How do I link 2 engines rotating in reverse?
« Reply #1 on: October 23, 2011, 12:54:27 PM »
Neat idea, lots of custom machining in your future. As I see it the motors will have to be offset a little and a gear mounted to the snout of each crank. As one engine rotates the gears are meshed and the other engine will rotate in the opposite direction as needed. Belts or chains are out as they will not allow counter rotation.
« Reply #2 on: October 23, 2011, 01:03:02 PM »
I really want to keep them inline, if I have to machine it I will have to have the in and out shafts inline and then reverse the rotation with a gear cluster off in the side of a box to reverse the rotation. Sort of a transfer case looking thing. I was really hoping that something was available though.
Offline RichFox
« Reply #3 on: October 23, 2011, 01:45:44 PM »
I believe that some of the twin engined cars built before are not linked. The ground is what links them together. Sort of like a train with more than one locomotive. Works for UP and should work for you. If I have failed to convince you of that, you could always look into running the forward engine with reverse rotation as is done on many boats. Then you could use commonly available couplers to link the engines.
« Last Edit: October 23, 2011, 01:49:31 PM by RichFox »
Offline hotrod
    • Black Horse photo
« Reply #4 on: October 23, 2011, 01:50:39 PM »
The Burkland 411 streamliner has 2 chrysler hemis mounted nose to nose with one of them running reverse rotation, but I am not sure if they are coupled at the crankshaft snouts or if they are free to run independent of each other. You might want to talk to one of the folks that has worked on the 411 to get the details of how it is set up.
Larry
« Reply #5 on: October 23, 2011, 02:17:30 PM »
Check with MSD as I hear that they have an ignition system that will keep both engines running at the same speed and as Rich says they are linked by the ground. I would think that if you could get them close via the ignition control then the ground link would take care of the rest.
« Reply #6 on: October 23, 2011, 02:44:35 PM »
Thanks for all the ideas, it definitely gives me some things to ponder. My two reasons for wanting to link them is concern for what the car would do if one end got a large amount of wheel spin independent of the other and also how bad it would probably get if you had a single engine failure. I originally was going to couple the two and run RWD only, but I think it is best to run AWD if I can.
Offline revolutionary
« Reply #7 on: October 23, 2011, 06:29:47 PM »
If it were me, I'd probably get two cranks with BBC snouts that were double keyed and just make a dampened coupler to join them. You could also do it with two coupler ends joined with a u-joint.  Basically making it a v16. Cams are easy to find in reverse rotation cores. Nothing too crazy.
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
« Reply #8 on: October 23, 2011, 08:52:07 PM »
From a safety standpoint I think two engines coupled like you plan could be a major problem if one engine fails and locks up the other would more then likely fail as well and what happens to the drive train.Best to talk to Tom Burkland regarding what they have.
« Reply #9 on: October 23, 2011, 10:19:15 PM »
I would run them as 2 seperate systems---and in light of what Glen said  I would not think of running them with out the ability for them to FREEWHEEL if something happens to one of the other  :-o
« Last Edit: October 25, 2011, 12:04:19 AM by SPARKY »
Offline Vinsky
« Reply #10 on: October 24, 2011, 12:51:46 AM »
If you have been following the Marlo Treit's Liner build, there are lots of good ideas there that could be applied to twin engined liners.
Offline Dean Los Angeles
« Reply #11 on: October 24, 2011, 10:10:55 AM »
If you don't couple them then you have the problem of running out of sync with each other and the difference in sync can cause major harmonic difficulties.
Offline ChrisLenahan
« Reply #12 on: October 24, 2011, 12:26:04 PM »
I would think that two engines running in reverse rotation would create a lot of stress on any connection between them due to torque. Even if the engines are solid mounted to the frame there will be some flex as the engines try to rotate in opposite directions.
  • In line
« Reply #13 on: October 24, 2011, 02:17:12 PM »
Clairifing :one engine running in normal rotation . the one facing backwards would be running in reverse rotation. ie both turning in the same direction
« Reply #14 on: October 24, 2011, 02:34:21 PM »
Well I guess I will ask the question... What are the common setups used in a multiple engine AWD liner? Or is there no such thing as a common setup?
