Quote "Verbage to this effect has been in the rulebook for several years"
My questions are of interpreting the words Dan. Rules should be explicit, not somewhat implicit that some one new has to keep asking "how does this apply", or "how is this interpreted"?
I thought I knew what N20 was and did, but not the way that the SCTA rule makers apply rules to it - the start of this thread.
However long I sit reading any of the US rule books here in the UK, the less I believe that any vehicle built (comp coupe in this case) with degrees of combustion innovation (and roof chop) will be legal on arriving at the salt.
So is it now 'the view' that if it has a spark ignition motor with turbine fitted in the exhaust but geared to the crank, then the only class for this 'turbine' motor is special construction?
That certainly was not clear from the the written words.
