Ivsalt
The 222 camaro has a four link also. The top bars are mounted in the very top holes the bottom bars in the very bottom this results in an instant center in front of the car.The rear springs are 110lbs. ProChassis didn't want us to change from 88lbs. but we added a big intercooler tank and water tank. the two weight boxes are full of lead,maybe to much.The car weighs 4680 lbs,3000lbs on rear 1680 on front.We have gone 288 mph at bville with a 279 exit speed and several times over 267+ We hold the AABGALT at El Mirage at 229 mph. I bought new 800/820 tires for it last year because i thought the old ones were getting to old, but get this, they still had the tits on them. We also run a 10 inch spoiler but almost flat which helps downforce. We can spin the tires in low gear but once in second it hooks up.
As i've posted before if you want to spin the tires, mount the rear end solid, or install a four link or other type of suspension with the instant center in the wrong place with too heavy springs.
You can view the car in build diarys [Getting ready for bville]
