Author Topic: Caster settings for Street Roadster  (Read 7287 times)
JohnR
« on: May 31, 2006, 02:18:33 PM »
I am building a roadster (30 A) that will see some running in SCTA XF/STR class as well as use on public roads.
I am getting ready to set the front caster (castor?) and want some input from guys who have roadsters. For a street vehicle, I am leaning towards 4-5 degrees but for the race usage I'm thinking 12-15 degrees. Of course, I want it to do both and can only set it once. Anybody have a vehicle with alot of castor for racing but then run it on the street? benefits? drawbacks?
Offline Bob Drury
Caster
« Reply #1 on: May 31, 2006, 03:30:47 PM »
John, I don't have a roadster, but this much I know.  The greater the caster, the harder it will be to straighten out after a turn.  You better keep it under 6 or 7 degrees , or you are courting disaster..............
Bob Drury
Re: Caster settings for Street Roadster
« Reply #2 on: May 31, 2006, 07:25:08 PM »
Quote from: JohnR
Are you running 4-bars, split wishbones, etc..  Why not figure out a way that you can change it back and forth?
c ya, Sum
c ya, Sum
JohnR
« Reply #3 on: May 31, 2006, 09:01:31 PM »
Quote from: Sumner
Quote from: JohnR
c ya, Sum
c ya, Sum
Split wishbones. I guess I could just have two sets of wishbones, but I guess I'm lazy and want something to do all of it.
Offline JackD
  • NOBODY'S FOOL
INVENT SOMETHING
« Reply #4 on: May 31, 2006, 09:14:25 PM »
Invent something and call it "Adjustable Ends".
Also remember the settings for the drag link so you can center the steering each time you change it.
Offline russ jensen
Re: Caster
« Reply #5 on: May 31, 2006, 11:32:05 PM »
Quote from: Bob Drury
:x don't know where this came from??? my brothers had so much caster the fenderless front wheels looked like a road grader in a turn & never gave a problem on many years of street use,it turned a little harder but it was like power stearing when it came time to straighten out, let go of wheel & watch it spin to ctr.. on mine I just went to motors manual & set for 40 ford and never had any trouble either, course never went much over 150.
speed is expensive-how fast do you want to go?-to soon old & to late smart.
JohnR
Re: INVENT SOMETHING
« Reply #6 on: June 01, 2006, 12:05:06 AM »
Quote from: JackD
Jack, I want to keep the stock wishbones for the original look. So that rules out a 4 link or a hair pin style with adjustable ends. I just like the look of the split stock wishbones.
Offline russ jensen
« Reply #7 on: June 01, 2006, 01:27:22 AM »
Quote from: JohnR
Quote from: JackD
:lol:  : :? where the split wishbone attaches to frame  use several  vertical mtng holes.
« Reply #8 on: June 01, 2006, 05:03:05 PM »
You can "pie cut" the radius rod and reset the angle right behind the front forging that attaches to the tube to put more caster in.  Al Simon did it that way on our race roadster with, I believe, '46-'48 radius rods.  Gives you a nice "stock" appearance with more caster, yet keeps to rods parallel to the ground so springing up and down has minimal effect on the caster setting, especially if you keep the rods long.
Offline hitz
« Reply #9 on: June 01, 2006, 07:31:54 PM »
John R,
  Picking the right caster setting has been a confusing study for me!
  Some of the information I think is right:
  Most of the excessive caster that you see on many of the salt flat cars is probably done to lessen the tire scrub.
  Excessive caster has a tendency to lift one of the rear wheels up when you turn the front wheels. Not good if you are sprung and have a long wheel base. Bad if you have a rigid short car.
  Some of the people on this forum have had good handling with the smaller numbers 6 to 8 degrees. One of the things that popped up while I was building my fat fender pick up front end was, some of the factory Camero caster settings were 0 degrees.(zero) :shock: go figure.
  You might give a thought to using Henry's stock setting. It is a early ford spindle ,isn't it? Take your time on the line up. Scatch that. That wasn't necessary. I've seen pictures of your Honda.
  My lakester is set up with 18 degrees of caster 8-[ .  It has no suspension but am making provisions to install it later. It has a designed(eye ball) wheelbase of 192". I'll put scales on the rear wheels when I have the differential mounted and see if the wheels have a tendency to lift when the frt.whls. are turned. If it doesn't I'll let you know and you can ignore this long-winded post
  Harv
Offline jimmy six
« Reply #10 on: June 02, 2006, 10:25:01 AM »
IMO the class and speed you want to run does not require as much castor as one may think. Personally I would try a few runs at 4-5 and see what happens. Your first runs are trials to begin with. I have 8 with a 28" tire a less with a 32" tire and been 216. Good Luck...
Offline GH
caster
« Reply #11 on: June 02, 2006, 11:22:02 AM »
I set my caster at 10 degrees +/-  on a Studebaker with 120" wheel base and a straight axle, 26" front tires, I drive it some on the streets and LSR, goes real straight, so far up to 228 mph.
« Reply #12 on: June 03, 2006, 02:46:10 PM »
John why not copy one of the most famous lakesters out there, Tom Beatty's 1950's lakester frontend (see picture).
He used an "A" axle as it is flatter.  Turned it upside down and re-bent the ends so that the camber would be right.  This then allowed the axle to be pretty close to the arch of the transverse spring for better aero.  The axle was now almost a straight axle.
He also reversed (swapped side to side) '40 ford ('37 to '48 are the same) spindles so that the drag link would be in front of the axle and close to the same plane as the axle/spring was in, again for better aero.
The wishbones where split to the sides of the car and he used center steering with a right side pitman.
From the picture it doesn't look like he is running that much caster.  The car ran 188 mph in it's first trip to the salt (1951) with a 296 Merc flathead and a 3-71 Navarro blower setup.  He entered the 200 mph club in '55 with a 211 2-way average.  In '62 he bumped his B Lakester record to 243 mph running a blown Olds, so the caster seemed to work fine for him.
If you can find "THE RODDER'S JOURNAL" Number 12 there are lots more pictues of the car and a good article on him and the car.
They also mentioned he ran this car at high speed on a dirt oval for an exhibition and mentioned how he would make 200 mph U-turns on the salt :D .
The other thing is these front end pieces aren't that expensive if you hunt around as not many rodders want the "A" axles so you could easily set up 2 front-ends.  One for the street and one for the salt.
c ya and have fun,
Offline hitz
« Reply #13 on: June 03, 2006, 05:01:15 PM »
Sum,
   Looks looks like zero camber to me on Beatty's tank! I was confused before and am more confused now.
JohnR,
  If you know what to set the caster at now after all of this information it would suprise me. The only thing I've come up with is, there's a whole lot more to make a car go straight than caster! Good luck with your roadster.
Harv
« Reply #14 on: June 03, 2006, 05:43:59 PM »
John -- I'll show you a similar (as I described above) set-up on my Sedan at the lake on Sunday.  I'm not techie enuf to snap a picture of it and post it.  But I think what I have used on two cars will suite your purpose.  Stan.
