Author Topic: Solo to Sidecar by STD  (Read 133878 times)
Offline Bruin
  • Just makin doo.
Re: Solo to Sidecar by STD
« Reply #285 on: August 01, 2015, 10:36:01 AM »
Wobbly, Your advice is appreciated and will go in the vault. I already finished the compound curves of the bottom pan with the poor tools and talent at hand. It's rough but it has a four inch radius all around the bottom joint. It ain't pretty but with some puddy it should be functional. I hope to mount the topsides today. Pictures soon.
STD; Speed Team Doo
'82 Honda 500 APS-AF
'70 Triumph 250 MPS-PG
'71 Triumph 250 APS-PF
'70 Triumph 250 M-PG
Offline Bruin
  • Just makin doo.
« Reply #286 on: August 02, 2015, 12:46:02 AM »
The cuts and folds look a bit rough but I'm hoping some Bondo will smooth things out enough that it will slip some wind.
STD; Speed Team Doo
« Reply #287 on: August 02, 2015, 01:56:06 AM »
Those rough areas can be blended together nicely by removing a rivet at a time, covering the area with soap, heating it up until brown, letting it cool, and tapping it down tight with a plastic pear hammer.  The rivet is reinstalled, the rivet next to it is removed, and the process repeated.  A pool ball might be a good dolly.
Offline Bruin
  • Just makin doo.
« Reply #288 on: August 09, 2015, 11:35:36 PM »
I thought a wheel cover and a sidewall on the hack might tame a little wind. Also, the side might help keep the co-pilot onboard.
The Flash Gordon toy is my beta model.
STD; Speed Team Doo
Offline sofadriver
« Reply #289 on: August 09, 2015, 11:56:55 PM »
If I was your monkey,  I'd demand a window.  :evil:
Mike in Tacoma
"aww, what the hell - let's just do it".............
Bike #833
100cc A/G, A/F and APS/G (in 2019)
« Reply #290 on: August 10, 2015, 12:05:17 AM »
I don't think the ray gun is legal. :mrgreen:
Offline Kiwi Paul
« Reply #291 on: August 10, 2015, 12:25:00 AM »
Nah, Mike, The Ray Gun just puts him into Fuel Class, yes?? :-D
« Reply #292 on: August 10, 2015, 12:38:38 AM »
Hmmm.  I concede to the inspector, who knows the obscure rules much better than I.   :roll:
Offline Bruin
  • Just makin doo.
« Reply #293 on: August 16, 2015, 11:56:05 PM »
I followed some of the tips above, annealed the fairing aluminum with soap as a temp gauge, drilled out the rivets on the ill fitting leaves, hammered them into a smoother overlap, and re-riveted. The compound curves are much smoother and will require significantly less filler to get that baby butt smooth effect. Thanks guys.
STD; Speed Team Doo
Offline Old Scrambler
  • Going Fast - Slowly
« Reply #294 on: August 17, 2015, 10:54:10 AM »
Brian................slow down and do it right..............you have another 12 months before we get to run.............maybe a cam is in your future :wink:
Offline Bruin
  • Just makin doo.
« Reply #295 on: August 19, 2015, 12:37:50 AM »
Admittedly, haste does make waste. But I feel like I should finish the build while I'm still on a roll.  It would make me feel better to have something positive come out of this season. A viable bike would be some consolation.
STD; Speed Team Doo
Offline Bruin
  • Just makin doo.
« Reply #296 on: June 18, 2016, 11:48:28 AM »
It has taken some time but I'm back on track with the sidecar hack. Originally the side-sled was built with a plywood bottom. I replaced it with sheet aluminum. Three pieces tacked on with screws and rivets and sealed with adhesive. The overlaps are shingled with the wind. It saves me about 6 pounds and is a much smoother skin.
STD; Speed Team Doo
« Reply #297 on: September 05, 2016, 01:24:31 PM »
So tell us about the 'rebuild' plan..........................I saw you at the SHELL and gave your wife a hug on the salt............ :-) :-) :-)
Offline Bruin
  • Just makin doo.
« Reply #298 on: September 10, 2016, 11:31:22 AM »
This year at the Motorcycle Speed Trials was great. After three wet years and a cancellation this year was a redeemer. There wasn't even water at the boat ramp. The salt was thin but the track was in fair condition. Best of all I even got to hotlap so that I didn't even have to stop at prestage or the start line. As for my runs... My engine fairing seemed to slow me, at 85mph its down by 5 mph. Too fat I suspect. Went faster without it. I ran with weights and passenger. Best passenger was 87mph. I started to slow down again and found that the front brake mechanism was sticking and dragging from a touch of rust. I pulled the shoes off. By the last day I managed to tie last year's speed at 90 mph running with weights. In general I found that I could hit 8,000 rpm (factory redline is 6,500) in 1st, 2nd, and 3rd. Then it flattened at 7,400 rpm in 4th, and 6,700 rpm in 5th. Because I have to run on the 1 mile track I can barely get to 5th at the timed mile mark. It is like a freakin drag race for me.
Next season: I am looking at a more aerodynamic position for me. I want to do a full Rollie Free layout but the rules say I have to sit or kneel. I'm also looking to gear it to run top speed in 4th and not use 5th. 4th gear ratio is 1.0 while fifth is a true overdrive at 0.84. Thoughts?
STD; Speed Team Doo
« Reply #299 on: September 10, 2016, 03:58:34 PM »
Maybe use a rear sprocket with a couple more teeth?
