Author Topic: Reciever Groove  (Read 7926 times)
Offline John Burk
Re: Reciever Groove
« Reply #15 on: June 02, 2016, 09:59:36 AM »
How hard is it to remove the head when the head gasket is sprayed with Coppercoat ?
Offline stay`tee
  • "Kawasaki ZX12 Turbocharged"
Re: Reciever Groove
« Reply #16 on: June 02, 2016, 05:19:47 PM »
 never had a problem  :-),, always clean both surfaces with Shellite before assembly,  :-)
Offline maj
Re: Reciever Groove
« Reply #17 on: June 02, 2016, 05:31:30 PM »
Ronnie have a chat to Peter at Ridgecrest engineering in Vic, he has supplied all our copper gaskets and specs to suit,
o ring intended for reciever groove is installed at different depth to no groove , and groove is about .020 wider than o ring in our application , but this is dependant on gasket thickness
Gets difficult if bores are close together , my big bore busa has the o rings siamesed , and Steves 14 probably needs same
 your 12 may be better
Offline Jack Gifford
Re: Reciever Groove
« Reply #18 on: June 03, 2016, 01:28:01 AM »
... o ring intended for reciever groove is installed at different depth to no groove , and groove is about .020 wider than o ring in our application...
Here's a sketch of dimensions that work for me with .024" thick copper.
Re: Reciever Groove
« Reply #19 on: June 03, 2016, 04:59:08 AM »
That looks really familiar Jack. We used about the same on a big block Chevy pavement sprint car on alcohol. It had serious compression and head gaskets were always nervous until we changed to that system No more problems.
Re: Reciever Groove
« Reply #20 on: June 03, 2016, 12:10:35 PM »
There you go, thanks to Jack's drawing skills.... On the bike motor the wire was 20 or 30 due to the amount of room available... On our big bore the wire was basically a figure 8, no room for side by side wires.
