Author Topic: Source for "Premium" bolts other than ARP?  (Read 7825 times)
Offline Crackerman
Re: Source for "Premium" bolts other than ARP?
« Reply #15 on: December 21, 2016, 01:47:45 PM »
I hate even thinking this... But if you cant find those anywhere, fastenal can make you some. They won't be cheap, i was quoted 60 bucks each on an oddball m13x1.25, depending on what its used for, tap out to new bolt size, or helicoil, and use a standard available not m
Offline maj
« Reply #16 on: December 21, 2016, 02:39:31 PM »
https://www.belmetric.com/10x10-extra-fine-c-6_339_359_907/
I would get the 45 and or 50 and cut to length so you have a shoulder to support the flywheel
« Last Edit: December 21, 2016, 02:42:13 PM by maj »
« Reply #17 on: December 22, 2016, 10:04:26 AM »
Great discussion, guys!  This kind of topic highlights why the Landracing.com forum is so valuable.
Through good fortune, someone contacted me directly with a set of connecting rod bolts from a premium manufacturer with specs that will work perfectly for my application.
The internet is great!
Offline bearingburner
« Reply #18 on: December 22, 2016, 12:51:48 PM »
Bolt depot list 10MX1.0 cap screws in 10.9 grade in various length for about $ 1.00 each
« Reply #19 on: December 23, 2016, 11:17:43 AM »
I ordered a set of 12.9 socket head cap screws from McMaster for mock-up purposes.
Depending on the rest of the varaibles in this setup, I may continue with the McMaster bolts, or use a set of connecting rod bolts from a different application.
steve.
