A supercharger (also known as a blower) is an air compressor used to force more air (and hence more oxygen) into the combustion chamber(s) of an internal combustion engine than can be achieved at ambient atmospheric pressure (natural aspiration).
That's straight from Wikipedia.
Naturally aspirated engines are limited by how much air you can suck into the engine.
Blown engines are only limited by the strength of materials in the piston, rod, crank, etc. If the turbocharger was the ultimate answer, then perhaps you can tell me why all the Top Fuel classes use a roots type blower?
Every blown record that was set with a turbo could have been done, and can be beaten by, a supercharger. The package size of the turbo lends itself to fitting in smaller spaces. Or maybe you should be using the setup on the diesel truck where twin turbos blow into a roots supercharger?
"When it eliminates competition" Isn't that every LSR racers goal? It sure is mine. I want to be able to have my great grand kids be able to see my record still in the books. (Note: I'm only 38 mph short of getting the record, and only need, oh say 40 on top of that to put it out of reach. Yep, that's doable!)
