I use a small CB125 bottom end with my project, and part of my testing was oil flow / pressure.
The stock Honda oil pump has all the flow you need, but as the bottom end uses a roller bigend bearing,and rollers in the 'box, high pressure will never happen.
I'm using a yamaha slipper bigend now, and after completely re-routing the oil flow, have pressure relief valve set at 50 psi, so the pump has the potential, you just have to split the flow, regulate the pressure, feed it to your turbo , then dump low pressure bleed of thru your engine.
Tiny
