Author Topic: Fuel cells, and battery mounts  (Read 3103 times)
Offline Vishnuatepork
« on: June 12, 2011, 01:56:42 AM »
So the idea came to me today, while I was looking at the dented tank onone of my donor bikes, to do away with the fuel tank on my motorcycle altogether.
Heres my thinking;
I am getting a Lithium battery that can fit under the back cowling, where the tool kit rests. Freeing up a space where the regular battery is. In addition to that space, I will be removing the air boxes, which resides infront of the battery.  This will give me an area (approx)7"x8"x 8".  And I thought it would be a good spot for a fuel cell. It would also allow me to get real low...., as well as being lighter.  2-3 liters is enough for me to make 2-3 runs I figure.
Having looked at what I can find with google, there is next to nothing in the parameters listed above.
Can I have my local welding guru fab one up for me?  Or are there certification (documentation) issues.  I figure so long its not dripping/leaking/pressure tested, all should be good right?
Secondly,
I know that the rules  state that the battery MUST be secured with a steel strap.  Would Stainless steel cable ties be considered a strap?
Cheers
Alan
Re: Fuel cells, and battery mounts
« Reply #1 on: June 12, 2011, 09:02:18 AM »
gas tanks can be constructed and used for racing... I have made several for the bike to aid rider position.  Any welder can build a leak free one from stainless or aluminum.  Be sure you have enough.
My opinion, No stainless tie wraps do not meet the requirement, you need to secure your battery.
Online Seldom Seen Slim
« Reply #2 on: June 12, 2011, 09:14:41 AM »
Fuel cell?  With H2 for fuel?  Unh, ask Ohio State and Rick Byrnes and others that have run high-pressure flammable/explosive gaseous fuel - about the extra issues you'll encounter because of that high pressure fuel tank.  Great idea, and certainly worth exploring - but it'll probably take some (lots?) extra effort to get it approved and running.  Go for it.
Offline Captthundarr
  • In line
« Reply #3 on: June 12, 2011, 09:59:11 AM »
Uh,Slim I beleive Vish is refering the fuel cells (tanks) that the race cars use. Plastic w/foam in them.
« Reply #4 on: June 12, 2011, 12:22:52 PM »
Do you mean enough gas?  where would I start sourcing all the alu hardware?
I am planning on running at Mojave, so its a short run, not a long course event for me.
Thanks
« Last Edit: June 12, 2011, 12:25:33 PM by Vishnuatepork »
« Reply #5 on: June 12, 2011, 08:42:19 PM »
Oh.  Sorry for the mis-guided guess.  Now that I see the "other" meaning of fuel cell -- oh, yeah, I remember now. . . :|
  • In line
« Reply #6 on: June 13, 2011, 12:01:33 AM »
That's Slim, Thinking waaaaayyyyy out side the box or cell as it were. :-D. Vish, 1/8th to 1/4" aluminum plate should serfice to start with. check speedway motors for weld in bungs for the "fuel" gas cap. be sure to vent the tank with a roll over check valve for safety. just some places to start.hope it helps.
« Reply #7 on: June 13, 2011, 08:05:08 AM »
Cheers
Alan
Alan
Not metal cable ties and not hose clamps
Offline JimL
« Reply #8 on: June 13, 2011, 09:05:01 PM »
Don't know for sure why, but my fabricated, flat panel, aluminum tank cracked in a few places (last year).  I was told to rubber mount it (done, done, & did).  I found that the little A/C line mounts (used on the hard lines from the condensor on many Japanese cars) work really well.  They have a 6mm stud on each end, like a miniature motor mount.  Get 'em at the Pick-A-Part....use nylock nuts just fine.
Regards, JimL
