I also have a Hobart but it is the 140 115V wire feed. I intentionally got the 115v model to ensure it was usable anywhere.
You can weld heavy material, but it simply requires you make a multipass weld. I have used it to build an entire exhaust system (20 gage material), lots of miscellaneous brackets, and jigs in the shop, and repair garage doors and other around the home issues.
I have used oxy-acetylene and stick welders but had not welded for 20 some years when I got this small wire welder.
My first project with it was to build a small welding table with some angle iron and some 1/8 x 1 and 1/8 x 2 inch flat bar stock.
I built the frame of the weld table out of the angle iron than created a top by welding the flat bar stock edge to edge. That required me to weld several 10's of feet of butt welds to build the top. By the time I had finished the welding table, I was back in the groove and had a good feel for the machine and what amperage and wire feeds to use, and had gotten my touch back. I also re-learned how to fill holes you will inevitably blow in the work as you learn to weld. The weld table does not need to be pretty so you can just burn some wire and try things. By the time you burn up a spool of weld wire you will be able to weld better than most home welders. You will also end up with a small "rough duty" table that will hold several hundred pounds and you can beat on all day without breaking it.
As mentioned above the Hobart is the "consumer" grade version of the Miller welders. They use the same design and components except some elements of the feed system are lighter duty components than used in the commercial machines (plastic rollers vs metal).
I use only the flux core wire, so I don't need to screw with gas bottles, and for typical around the shop applications like tack welding a jig together or fixing a cracked frame of a log splitter or something like that it works just fine. Also you can use the flux core wire outdoors when it is a bit breezy which you cannot do with gas welding because the wind will blow the gas shield away.
Welds are not as clean looking as gas welded mig, but they can be just as strong if you use good technique (translation take the time to get good fit-up on your materials so you are not trying to fill large gaps).
I have welded material up to 1/4 inch thick with it using multi pass welding ( the same as the ship yards that used to weld 6" thick steel with stick welders) You just make a root pass at the bottom of a V'eed out joint and then make multiple passes to fill the V.
It takes some time and you have to learn to control (anticipate) weld shrinkage, but it works quite well for home shop type repairs and simple non-critical fabrication.
Larry
