"Would it not be more helpful to the LSR community to release (not necessarily all) details of what happened to have "four insurance related incidents in a two day event" so that we could be aware for the next event?"
OK, who has not heard of the Mariani streamliner crash? He was close to going out of bounds, tried to save it, didn't.
#2 - a car under power out the back door
#3 - a turn out into the spectator area, out of bounds
#4 - a motorcycle on a tow line that screwed up, tossed the rider(with injuries) and also caused his wife to fall of the towing quad(with injuries)
If you need more detail, please contact the persons I mentioned above.
Three of the four are already covered in the El Mirage procedure manual. The out of bounds regulations , with penalties, have been in the manual for a couple years. Unfortunately, the competitor's actions force the penalties to become stiffer each year. Maybe some day we will reach a level where the entrants will take on the responsibly of conducting a safe meet. The 4th item above is now a part of the procedures.
From another post in this thread:
"Improper belts?? Example please."
The required HNS will require the use of 2" shoulder belts to work properly. This is covered in the rulebook. The mounting points for some of the HNS are not the same as the rulebook. You are asked to mount your belts in accordance with the manufacturer, many have notand the belts can be pulled of the driver's shoulders. This in effect makes the complete system ineffective.
