For what it's worth, I'm going to give you a run down on truing the Wheelsmith wheels I purchased for my Bonneville roadster. All of the wheels are at least .025" out at the bead side to side and up and down. I just called Chris at Wheelsmith to explain the problem. The first thing he told me is it doesn't make a difference if the wheel wobbles, just true the tire so they both wobble the same! No sh.t, that's what he told me. My feeling is if the bead is not concentric, then you mount a tire and true it to be un-concentric, at 230 MPH can your eyeballs stay focused? The other thing he told me is the wheels are lug centric, i.e., the lug nuts locate the wheel on the hub. I'm not an expert, but I spent a whole Saturday with a dial indicator, my wheels and hubs on the axles mounted on a bench. I've mentioned this before but it's worth repeating. What I found, is the sequence that the lug nuts are tightened determines how they locate on the hub. We're not talking about how the wheels are clocked on the hub, we're talking about the lug nuts loosened, then re-tightened a different way changes the run out of the wheel.
Am I being a little too anal here. Should I just put the damn things on my car and run them?
