JH;
All the theoretical stuff aside, my test of a new filler rod, type of weld, material, etc. is to weld two pieces of tubing together at 90 degrees, sort of "T" shaped. Then put it in a big bench vise and bash the heck out of it with a heavy hammer. If the tubing bends and folds up rather than breaking the welds, you're OK. One advantage of this "non-quantitive" test is that it tests the joint for shock loads rather than just static loads.
Regards, Neil Tucson, AZ
