I am not a parts store the following are from a project that never even started.
I bought ALL the following parts from summit racing for a drag car I was building but prioritys change and these have to go.
EVERYTHING IS BRAND NEW NEVER INSTALLED, if you would like pics of a spacific item id be more than happy to send them.
Check
www.SUMMITRACING.com to see if these fit your application.
I willl list summits part # and their current price. Make me a REASONABLE offer, Low Ballers will be ignored. Example, I WILL NOT sell my $3500 supercharger for $500.
Aeromotive Fuel filter Part # AEI-12301 $83.95
ARP High Performance Series Cylinder Head Bolt Kit Part # ARP-134-3601 $73.48
ARP Stainless Steel Cylinder Head Bolt Kit Part # ARP-434-3601 $159.95
ARP Engine Bolt Kit Part # ARP-534-9601 $120.95
Comp Cam Nitrous HP Camshaft Part # CCA-12-564-4 $138.95
Comp Cams Ultra Pro Magnum Rocker Arms Part # CCA-1602-16 $323.95
Dart Chrome Valve Covers Part # DRT-68000050 $57.95
Eagle Connecting Rods Part # ESP-6000B3D $373.95
Fel-Pro Performance Intake Manifold Gasket set Part # FEL-1204 $14.95
Mieziere 100 Series Electric Water Pump Part # MEZ-WP101B $309.95
Miezere NPT to Smooth Hose Adapter Part # MEZ-WP1175B $19.99
Milodon Oil Pump Pickup Part # MIL-18311 $42.95
Milodon Street and Strip Oil Pan Part # MIL-30900 $163.95
Milodon Lifter Valley Baffle Part # MIL-32610 $34.95
Milodon Windage Tray Stud Kit Part # MIL-81150 $53.95
Moroso Solid Steel Motor Mounts Part # MOR-62515 $25.95
Moroso Solid Steel Motor Mounts Part # MOR-62630 $45.95
Moroso Solid Transmission Mount Part # MOR-62600 $23.95
Mr Gasket Street Scoop Part # 6650 (cant find on summits websight any more)
Mr. Gasket Valve Cover Gaskets Part # MRG-175 $11.95
MSD 6BTM CD Ignition Part # MAD-6462 $374.95
Powermaster Alternator Bracket Part # PWM-885 $86.95
RCI Transmission Blanket UNIFERSAL, RED, Nylon, SFI 4.1, 11.5" x 47" Part # RCI-7808A $89.95
SRP Pistons Part # SRP-203195 $541.88
Teague Intercooler Part #SCI 671-1471-12 $1695.00
Weiand 6-71 Part # WND-7487P $3,573.99
DO NOT ASK ME "IS THIS ITEM STILL AVAILABLE" OR YOU WILL BE MARKED AS SPAM
When I sell something I will remove it from the list. When you contact me please put in the subject line "I DONT WANT YOUR CHEVY PARTS" as another measure so I know your not a spammer.
I have more to sell...
