Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 657410 times)
Re: MS LIBERTY a Wild Weasel's belly tank
« Reply #2130 on: February 20, 2016, 04:01:42 PM »
No Bill Ratcliff of Lillian Texas--- Arlington Four Wheel Drive---the most knowledgeable "Gear Guy" I have ever met!!  A true wealth of knowledge!
« Last Edit: February 20, 2016, 04:03:34 PM by SPARKY »
Miss LIBERTY,  changing T.K.I.  to noise, dust and RUST!!!
           tncsg.org     mrspowell.org
ELECTION  INTEGRITY  PROJECT
eip-ca.com  EIPAz.org  eipnv.
« Reply #2131 on: February 20, 2016, 04:08:25 PM »
Marty cut the ends off tacked the Ford housing ends on dropped by Thursday night.  I was on CL last night and scored a 9" a guy was running in his 66 Chev PU  already had after market rear axels with a 4.89  posi in it
I will use the drum brakes  from it and will use the rest for $$$$$$$$$$$
« Reply #2132 on: February 23, 2016, 02:16:55 PM »
Geee'z Craigs List is about as bad a HF  I was cruising around a ran across a listing about a 1977 Conseco Car hauler--Sale Pending  good price  I let the guy know I might be a player depending up on the dimensions---long stor short this guy Dan and his buddy baught it out of the Ernie I. estate sale in CA. along with most all of the Ford Indy camer stuff spring of 2006.  It has been a storage trailer for the last ten years but Ms Liberty will fit inside barely .
Online Speed Limit 1000
« Reply #2133 on: February 23, 2016, 04:03:28 PM »
Stainless still has the long trailer.
« Reply #2134 on: February 23, 2016, 07:15:09 PM »
How long is it?
« Reply #2135 on: February 24, 2016, 04:12:12 PM »
40 foot gooseneck I think....
call if you need specifics  :cheers:
« Reply #2136 on: February 24, 2016, 05:50:39 PM »
Mine is a 1977 Conejo 35'  what brand is yours.
Is anyone familiar with this brand of trailers?
Offline 37str
« Reply #2137 on: February 25, 2016, 01:57:35 PM »
Sparky,
      Conejo is a great trailer.
« Reply #2138 on: February 25, 2016, 04:24:44 PM »
Haulmark Elite 2 40 ft, 3 axles... currently full of fiberglass pieces and other junk...  :|
« Reply #2139 on: March 02, 2016, 10:38:09 AM »
progress is being made--batteries bought, key made,  switch replaced
--wowie-- zowie--back ramp goes up and down
Called Marty and he came by with one of the axles turned down ready to be re-splined for the El M axle
My job of the day is to wire in some fuses and finish the re wiring that Marty had to do on the pump wiring on the front hyd ram that raises the trailer for hooking up.
Hopefully we will be able to start the re-spline soon.
« Reply #2140 on: March 04, 2016, 07:37:43 AM »
Started on checking out the trailer wiring will need for some rewire replacing a few lens and fixtures.
« Reply #2141 on: March 04, 2016, 07:58:40 AM »
axle update
01  this is the remains of a Ford 9" yoke that had 28 splines  cut it down to 1.750 and we were the axle to use a piece of 1.750 dom tubing as an alignment tool
02 & 03 the remains of a GM 4x4 frt. axle shaft and bearing that he used to mount the old 4 jaw chuck to
« Last Edit: March 04, 2016, 08:09:35 AM by SPARKY »
« Reply #2142 on: March 04, 2016, 08:11:51 AM »
mounted up
« Reply #2143 on: March 04, 2016, 09:01:35 AM »
You may want to look into getting those axles heat treated after you've resplined them. I've had experience with doing 9" Ford axles in the past and without heat treatment they'd shear off right where they entered the side gears.
Good luck.  :cheers: :cheers: :cheers:
« Reply #2144 on: March 04, 2016, 12:43:03 PM »
Will look into it
