Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 699080 times)
Re: MS LIBERTY a Wild Weasel's belly tank
« Reply #1965 on: March 10, 2015, 10:09:00 PM »
Well I first drilled them in 2 bolt holes  so that I could bolt/clamp the 3 plates together---aligned them as best as I could--then milled the two locating 5/8" with an end mill---pushed in my 5/8" dowels( they were a loose slip fit) then end milled all of the 3/8" bolt holes---
In the am will bolt them all together and sand all three to where the will clear the flex plate starter ring gear----then bolt up a trans an see how it goes
Larry Pater, a LSR MC guy from the Chicago area and his buddy Doug who lives here in the valley came by for a great 2 hour "get to know you/bench racing session"  good times  :cheers:
Miss LIBERTY,  changing T.K.I.  to noise, dust and RUST!!!
           tncsg.org     mrspowell.org
ELECTION  INTEGRITY  PROJECT
eip-ca.com  EIPAz.org  eipnv.
« Reply #1966 on: March 11, 2015, 02:54:23 PM »
Well , we got'r done  guess what the trans locating pins are not symetrical---don't ask me how I know
I now have them bolted together and will finish shaping them so they will be interchangeable
also from my researching the LS engines apparently they duplicated the oil passage of the front to the block on the rear ----so here is my efforts
 also I will need to restrict the lifter oil by bushing the lifter galley from the 9/16 to 7/16"  I will research this some more but I bet it is only on the one that doesn't feed the mains---this block does not have priority oiling for the mains---
Then to the machine shop to get the block cleaned, trued, decked piston, squirters installed so that we can order pistons and bore it.
« Reply #1967 on: March 12, 2015, 08:14:14 AM »
hopefully will get the mid plate finished today so that I can use them to offset punch the missing LS trans. bolt hole.
I am sure that a lot of this stuff I am JUST being paranoid about but the "sig line" at the bottom of Fordboy's post "about the attention to the little things" just keep ringing through my head.
« Reply #1968 on: March 12, 2015, 04:00:16 PM »
Sparky,
Thanks for the reference.
I'm a bit paranoid too.
But I can tell you ONE TRUE THING about details . . . .
I'd rather be a bit paranoid, than be the teensiest bit stupid or lazy . . . .  that, bites you in the a$$, EVERY TIME.
I've only been to the salt once, but I've been to countless race tracks over the decades, and guess what:
Nobody WANTS to be the guy with the stupid problem, but those problems occur because nobody bothered to check some small, seemingly insignificant detail.
Why?    Because everybody KNEW it would be OK.     OOPS . . . . .
Run time/Race time should be just that, because so little is available.    It shouldn't be time to try and fix stupid sh**.
Bottom line is:  Somebody needs to check.   Everything.
Offline Jack Gifford
« Reply #1969 on: March 13, 2015, 01:23:55 AM »
... than be the teensiest bit stupid...
Hey! You're talkin' to an awful lot of us folks!
M/T Pontiac hemi guru (or does guru status expire after 30 years?)
« Reply #1970 on: March 13, 2015, 01:30:05 AM »
lol   so true  :cheers:
« Reply #1971 on: March 13, 2015, 08:45:49 AM »
Stupid sounds so harsh.  For myself, I prefer woefully ignorant.   :mrgreen:
« Reply #1972 on: March 13, 2015, 09:25:28 AM »
OOOPS!!
Sorry Jack.    I was mainly talkin' about myself there . . . . .
F/B
« Reply #1973 on: March 13, 2015, 09:30:27 AM »
Stupid . . . . .   woefully ignorant . . . . .  meathead . . . . .  oafbrained . . . . . etc . . . . .
Pretty sure I don't like any of them.
F/B
Offline Frankie7799
« Reply #1974 on: March 13, 2015, 04:45:48 PM »
I was under the assumption that an LS block and an older SBC/BBC had the same bolt pattern where the trans and engine mate up. Only a spacer was needed in the back of an LS crank for an older TH or PG input shaft to ride in it? Is this not the case Sparky?
Offline redhotracing
« Reply #1975 on: March 14, 2015, 08:27:13 AM »
There's an extra bolt hole at 12 o'clock, but other than that, it's a direct mate up. We use a McLeod bellhousing specific to our drivetrain (LS -> Jerico)
and it's worked really well the past 5 years. My brother has an LS with a TH400 behind it, he uses a spacer to mate things up.
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Offline Frankie7799
« Reply #1976 on: March 14, 2015, 01:33:39 PM »
Ah, thanks for the clarification  :cheers:
« Reply #1977 on: March 15, 2015, 11:26:34 AM »
Sorta , all of the above:
---- the LS block does not have all of the holes drilled and tapped
 early 6.0 cranks do not need the spacer
« Reply #1978 on: March 15, 2015, 05:14:58 PM »
back of block
Offline Frankie7799
« Reply #1979 on: March 15, 2015, 05:18:31 PM »
Yep, I see the problem now. Thanks for the clarification Sparky
