Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 715161 times)
Re: MS LIBERTY a Wild Weasel's belly tank
« Reply #1935 on: February 24, 2015, 08:53:42 PM »
WOW MR. PODUNK SIR  them are some pretty shoes for me girl Ms Liberty,  I bet she is going to love them.
May I suggest that you at least bring your camera's date/time stamp up to speed or drop it off?
« Last Edit: February 25, 2015, 07:17:04 AM by SPARKY »
Miss LIBERTY,  changing T.K.I.  to noise, dust, rust & scrap!!!
ELECTION INTEGRITY ALLIANCE(r)   founding member
ELECTION INTEGRITY PROJECT(r)
eipaz.org  member of Election Integrity Project(r)
eip-ca.com  eipaz.org  eipnv.org
« Reply #1936 on: February 25, 2015, 08:30:15 AM »
Podunk,
If you need to get an incorrect date off of a digital photo, I suggest GIMP photo editing freeware.
Offline lsrjunkie
« Reply #1937 on: February 25, 2015, 10:04:36 AM »
Nice work Podunk! Love it! Can't wait too see the little lady with her new shoes in person!
« Reply #1938 on: February 25, 2015, 04:59:45 PM »
Sparky,
Great looking wheel and tires!!!!
« Reply #1939 on: February 25, 2015, 10:57:11 PM »
  :dhorse:  Those "Autos" mount up just fine on those "MCs"   :-D
« Last Edit: February 26, 2015, 09:31:12 PM by SPARKY »
« Reply #1940 on: February 26, 2015, 09:38:58 PM »
Francis is coming up in the Morning should be here around 10:00 with more canopy work the camera will be at the ready!!!!!
Spud from FIE called about the old Vertex mag I scored off ebay---even though it was recently rebuild it is WEAK  only about 11 millli amps  with a couple of tweaks and one of his killer black coils  we can get it up to around 22-23  should be good for running blown gas/NA alky  maybe low boost E-85,  any way we should be able to conform to Classic Rules!!
Offline SPDRACR
« Reply #1941 on: February 27, 2015, 12:01:07 PM »
Sparky, I most likely missed it but What car are You going to put Your "classic LS turbo" motor in?
I did not think that there was a classic Lakester class.
salt is OK, but the DIRT is where it's at!
Proud 2nd generation Roadster Racer
Muroc 2 club, El Mirage 2 club
« Reply #1942 on: February 27, 2015, 08:53:27 PM »
Don't know, what may come down the Pike---for now we are going to run it in Ms Liberty  and see if we are smart enough to run gas with a blow through  and see what develops.
« Reply #1943 on: February 28, 2015, 09:56:25 AM »
Hey Sparky, I have a blow through on my tank & I went at it knowing nothing & using logic. To avoid turning a good engine into a cutting torch I hooked up a 3" EGT & a boost gauge beside the tach & dialed it in that way. Correct jetting is a compromise between a fat bottom end & a lean top end. I built my own carb out of other peoples cast-off Holley parts, I am a dumpster diver after all. :roll: I can download my memory bank on this $hit if you want some help.
« Reply #1944 on: February 28, 2015, 10:14:12 AM »
sure  pm comming
« Reply #1945 on: February 28, 2015, 10:21:35 AM »
thanks  Sid
« Last Edit: February 28, 2015, 10:23:15 AM by SPARKY »
« Reply #1946 on: March 07, 2015, 07:19:14 PM »
For those who wish to run a magneto on an early small block Ford 221-260-289motor---
  Spud at FIE  FuelInjectionEnt.com (1 541-990-2485) can supply them or adapt you mag to this early Ford dist housing.  This is the dist. drive that GM put on their frt adaptor of the LS motor.
« Last Edit: March 08, 2015, 11:56:46 AM by SPARKY »
« Reply #1947 on: March 08, 2015, 12:08:13 PM »
Shop day  long over due---coming up  rear motor plates drilling sizing and fitting
I have been disposing of a giant cactus that committed suicide by consuming to much water after it started leaning several years ago---these things do not adapt to developed areas well there is too much run off.  Thank goodness there was a guy that has a small JD with a frt. loader that lives down the street and Marty has a dump trailer you can pull behind a pickup.  Three very nasty days of cutting the thing up with my small chain saw, 3 days , three trips, and $89.00 to the city dump for excessive tonnage  but we saved over $1500. for the Race Fun, fund.  We were quoted over $2000. to remove it.  Turns out the thing weighed almost 10,000 lbs---
« Reply #1948 on: March 08, 2015, 12:24:16 PM »
This is the lower trunk after drying out for a week when it first fell, the ribs were much smoother from having so much water.  When I first was moving it if you broke the skin juice would skirt, then ooze out
« Reply #1949 on: March 08, 2015, 01:00:09 PM »
Yeah it can be pretty eye opening on trees and the like.
Just before my dad died, a storm came through and damaged a 30 year old willow tree on the property on the channel.     The woodcutters sold the take downs for firewood so every thing was weighed before removal . . . . .
over 32,000 pounds
and they charged him $2,800.00, and that was in 1999 . . . .
