Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 715152 times)
Offline Jack Gifford
Re: MS LIBERTY a Wild Weasel's belly tank
« Reply #1725 on: June 15, 2014, 01:13:07 AM »
... yesterday was Friday the 13th...
That could not have been his problem. As Pogo used to say in the comic strip- "When Friday the 13th falls on a Friday, all is well; but when Friday the 13th falls on a Tuesday... or a Saturday... or whatever- watch out!" :evil:
M/T Pontiac hemi guru (or does guru status expire after 30 years?)
« Reply #1726 on: June 15, 2014, 08:50:11 AM »
LOL
Miss LIBERTY,  changing T.K.I.  to noise, dust, rust & scrap!!!
ELECTION INTEGRITY ALLIANCE(r)   founding member
ELECTION INTEGRITY PROJECT(r)
eipaz.org  member of Election Integrity Project(r)
eip-ca.com  eipaz.org  eipnv.org
« Reply #1727 on: June 15, 2014, 02:07:13 PM »
I got my brackets cut out and cleaned up---but I am going to wait until I have a second pair of hands and eyes to measure to make sure I have a better shot at alignment ---just as soon not have Ms Liberty not dog tracking down the track.  :-o
« Reply #1728 on: June 16, 2014, 12:27:10 AM »
Well I could not stand it I just kept going back, watched,, the race for a while  worked in shop,  watched the ball games for a while back to the shop---I think I am there,  decided to sleep on it then will hard tack in the am.. an get some more eyes.
« Reply #1729 on: June 18, 2014, 09:10:11 AM »
Marty came by last night and welded the axle brackets to the new axel and the frame brackets so I now have a axle I can take in and out.  I am taking the time to reroute the brake lines to shield them from the turbos when we get there.  Once again  I am reminded why folks say that Special construction takes 3 to 4 times as long as door slammers.  Every thing is a long thinking process as well as having to "BRACKET RACE" your way through the whole process.
« Last Edit: June 18, 2014, 12:03:33 PM by SPARKY »
Offline kustombrad
    • Project No Bucks '49
« Reply #1730 on: June 18, 2014, 09:36:59 AM »
You're telling me!  :-D
« Reply #1731 on: June 18, 2014, 09:58:32 AM »
Marty came by last night and welded the axle brackets to the new axel and the frame brackets so I now have a axle I can take in and out.  I am taking the time to reroute the brake lines so shield them from the turbos when we get there.  Once again  I am reminded why folks say that Special construction takes 3 to 4 times as long as door slammers.  Every thing is a long thinking process as well as having to "BRACKET RACE" your way through the whole process.
100% Sparky. :cheers:
The stuff never stops and you have to be 10 steps ahead when doing anything.
« Reply #1732 on: June 18, 2014, 11:18:38 AM »
Amen to that, Sparky!
Offline Dynoroom
« Reply #1733 on: June 18, 2014, 12:07:00 PM »
 :? :? :?    :-D    :mrgreen:
« Reply #1734 on: June 18, 2014, 10:27:50 PM »
John came over for about 4 hours---we got STUFF done,, the oil pan is now all hooked back up and all the dry sump lines installed.
  the axle is bolted in and it aligns nicely
 the brake lines are in they are UGLY but you can't see the ugly and they are functional
I should be able to finish most of the axle  and start reinstalling the water tank  then on to the carb and tps stuff.
« Reply #1735 on: June 19, 2014, 02:29:00 AM »
Go Sparky :cheers:
« Reply #1736 on: June 23, 2014, 12:05:19 PM »
Got one of the brakes done and found a defective wheel cyl--some more of that great chi-com stuff replacement parts for Ford 9"---will get it done today Andy and I will bleed the brakes tonight
 -mostly I will work on getting the TPS installed inside my air intake scoop system.
« Reply #1737 on: June 23, 2014, 10:22:54 PM »
Andy came over for an hour to night---we bled the brakes and adjusted the shoes---I finished the brakes the AM and worked on the fuel system and TPS off and on this afternoon.
Thanks Sum for all you have done toward this Data Logging stuff
« Reply #1738 on: June 24, 2014, 01:53:42 PM »
bracket racing---arghhhhh  :x  been "fitting" Sum's TPS switch on my car plate ---finally done--now have to make mounting bracket and a new return spring "stand" for the carb and get this part wired.
bracket--- smacket ---who likes making brackets
Online Elmo Rodge
« Reply #1739 on: June 24, 2014, 03:36:54 PM »
I like making brackets. I like everything.  :-) Wayno
