Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 715432 times)
Re: MS LIBERTY a Wild Weasel's belly tank
« Reply #1695 on: May 28, 2014, 11:02:33 AM »
« Reply #1686 on: May 27, 2014, 07:48:13 PM » Quote
Well one worked!
COOL,  :mrgreen: never seen a 12 to 13 inch Micrometer before!   :cheers:
Wow! It is a micrometer. Wayno
« Last Edit: May 28, 2014, 11:07:54 AM by Elmo Rodge »
Offline Podunk
« Reply #1696 on: May 28, 2014, 12:49:33 PM »
Actually it's a 16" to 20" mike. I was able to resize a photo taken before Sparky told me how to use my camera. This is what we started with.
Offline Geo
« Reply #1697 on: May 28, 2014, 01:42:28 PM »
Wow!  Extremely nice job on the wheels.
That must be a Midget Micrometer!  :evil:
Geo
« Reply #1698 on: May 28, 2014, 02:13:00 PM »
Thats a lot of saw cutting, must have taken a few minutes.  :-D
Offline Finallygotit
« Reply #1699 on: May 28, 2014, 02:18:01 PM »
I'm thinking water jet.  Too nice a cut for a saw.  :cheers:
Dan
Tucson, AZ
« Reply #1700 on: May 28, 2014, 05:28:54 PM »
And the winner is---Envelope Please-----WATERJET!!!
Wow those things look like they belong on Fred Flintstones  Log Mobile!!
« Last Edit: May 28, 2014, 05:43:41 PM by SPARKY »
Miss LIBERTY,  changing T.K.I.  to noise, dust, rust & scrap!!!
ELECTION INTEGRITY ALLIANCE(r)   founding member
ELECTION INTEGRITY PROJECT(r)
eipaz.org  member of Election Integrity Project(r)
eip-ca.com  eipaz.org  eipnv.org
Offline Podunk
« Reply #1701 on: May 28, 2014, 07:00:56 PM »
Same brakes. :-D
« Reply #1702 on: May 28, 2014, 10:06:01 PM »
no brakes man this is LSR
Offline Jack Gifford
« Reply #1703 on: May 29, 2014, 12:33:40 AM »
... it's a 16" to 20" mike...
The micrometer barrel sure doesn't appear to have 4" of travel. Are there removal anvil extensions?
M/T Pontiac hemi guru (or does guru status expire after 30 years?)
« Reply #1704 on: May 29, 2014, 11:19:52 PM »
Oops... meant 'removable'...
« Reply #1705 on: June 01, 2014, 06:41:59 PM »
  weights with transport tires and me standing where my belly button is----will install race tires, fire suit and transfer water to tanks where it will be when we leave the line Monday.  will not change it much
207 wb
LF               RF
682             510    = 1192
LR               RR
952             1116  = 2068
                    Total    3260
almost exactly what the old car weighed  :-o
Online Peter Jack
« Reply #1706 on: June 01, 2014, 07:56:58 PM »
You have a bunch of wedge in the car. It may tend to pull to one side. It won't be a good oval car because the wedge is the wrong way!  :-D :-D :evil:
« Reply #1707 on: June 01, 2014, 08:25:27 PM »
lol
   682                       1116
-  510                     -   952
= 172/2=86            =  164/2= 82
PJ   this is just a SWAG on my part  at trying to offset the eng torque &  pinion trying to lift the right rear.  Hopefully underway it has a better chance of going straight .  This thing is seems to be pretty responsive to changing tire pressures.  It seems to be fairly torsionally ridged.
Online Stainless1
« Reply #1708 on: June 01, 2014, 08:31:54 PM »
I was about to ask if you factored in torque.... I guess you did  :cheers:
« Reply #1709 on: June 02, 2014, 12:45:29 PM »
hot off the scales with race tires no wheel disks   :-o
  LF              RF
  636            506      1142
  953          1081      2034
                               3176  total
205" wb
cg 131" aft of the front axle
CG with driver on board is at the frt motor plate without driver 6" rear ward  hard to believe this car is 75 lbs lighter than the old car  but right now I only have 180# of ballast the old car had almost 300 and 2 batteries that sat right in front of the rear axle.  I could get another 180# in without turbos.
« Last Edit: June 03, 2014, 07:15:25 PM by SPARKY »
