Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 698444 times)
Offline Frankie7799
Re: Wild Weasel a TRUE belly tanker
« Reply #1470 on: October 29, 2013, 11:42:33 AM »
Good luck Sparky!
« Reply #1471 on: October 29, 2013, 11:50:34 AM »
Like Frankie said.
 When will you have pics?.  :cheers:
« Reply #1472 on: October 29, 2013, 11:46:27 PM »
I had a good afternoon, working on the secondary chute systems.
 Andy came over tonight and we got the new bottom panel in.
 I will wire the gauges tomorrow and put in the belts, and order more springs for the  Dutzs fasteners. We are down to cutting and fitting the last four panels---above and below the headers and then double checking all the fittings, finish mounting the intake scoop  and -------------then the GAS!!!!!!!!
Miss LIBERTY,  changing T.K.I.  to noise, dust and RUST!!!
           tncsg.org     mrspowell.org
ELECTION  INTEGRITY  PROJECT
eip-ca.com  EIPAz.org  eipnv.
« Reply #1473 on: October 31, 2013, 12:41:12 AM »
ran out of DZUS springs  getting the gauges in and checking fittings more of the same Thur. AM
Offline 38flattie
« Reply #1474 on: October 31, 2013, 05:51:03 AM »
I better get busy and make sure I have a date with "Ms Liberty". Andy and I cut the new panels for the bottom and the 4 panels that the above and below the headers.  I will try to start cutting out for the headers and welding some tabs  today. Instruments and seat belts up front.
OK, what is Ms Liberty?
http://youtu.be/89rVb497_4c
« Reply #1475 on: October 31, 2013, 08:30:16 AM »
That is the name of my "F-105 tank" Wild Weasel" ---think Nose Art
Offline 38flattie
« Reply #1476 on: October 31, 2013, 08:33:08 AM »
Thanks Sparky-somehow I missed that!
Car is looking great! :cheers:
« Reply #1477 on: October 31, 2013, 08:57:09 AM »
"Miss Liberty" was built with one thing in mind   :wink:   To show someone a good time    on the bed  :-o      Dry Lake Bed that is  :-D
Offline 38flattie
« Reply #1478 on: October 31, 2013, 09:35:57 AM »
LMFAO! :cheers: :cheers:
« Reply #1479 on: October 31, 2013, 02:32:19 PM »
Well all in all a good morning--- the electrical system is now partially hot:
 Cut off works, master works, Ign.  hot-- starter button works,   RAD in Box  cooling pump, works and no leaks, Transfer pump box water back to rear tank works--- two small leaks now stopped.  That just leaves the tach and water and oil press to wire and make up the connectors so that we can take canopy and strg. wheel off..woops forgot to mention the 22 gallons of distilled H2O
« Last Edit: October 31, 2013, 02:35:12 PM by SPARKY »
« Reply #1480 on: October 31, 2013, 02:33:36 PM »
Sparky now you sound like Doug Odom! "If you can't race it or take it to bed - it ain't worth having."  :-D
« Reply #1481 on: October 31, 2013, 03:30:57 PM »
You see how Sparky's keeping us in suspense?. Not fair. We need pics. :-D Nose art too.
Offline 38flattie
« Reply #1482 on: October 31, 2013, 03:40:18 PM »
Sparky, whay is the 22 gallons of distilled H2O for?
« Reply #1483 on: October 31, 2013, 05:47:35 PM »
I run distilled water in everything --so the heat will not cause mineral deposits anywhere --they inhibit heat transfer
Offline 38flattie
« Reply #1484 on: October 31, 2013, 06:14:40 PM »
No mineral deposits to deal with, but I though distilled water caused more corrosion, due to the water trying to 'balance' itself, and leaching minerals from all of the metal?
I think deionized water is worse, if I remember correctly.
