Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 715149 times)
Re: Wild Weasel a TRUE belly tanker
« Reply #1410 on: October 04, 2013, 11:42:21 PM »
again a strange productive day  :?   it was a bounce around the car day work on this work on that!!Andy and I should be able to get in 3 hours Saat. am---
John said he maybe able to come over Sun. for a while
« Last Edit: October 06, 2013, 08:48:07 AM by SPARKY »
Miss LIBERTY,  changing T.K.I.  to noise, dust, rust & scrap!!!
ELECTION INTEGRITY ALLIANCE(r)   founding member
ELECTION INTEGRITY PROJECT(r)
eipaz.org  member of Election Integrity Project(r)
eip-ca.com  eipaz.org  eipnv.org
« Reply #1411 on: October 05, 2013, 04:19:55 PM »
Andy and I had a great productive time this AM  2 hours cleaning up and getting stuff out of the shop and  then we stuck the nose back on.  The fire sealant foam really stretched the skin round and tight around the tank bay---it was much harder getting the nose back on.  I hope to have another productive session late this afternoon.  Maybe John and I can get going on the canopy Sunday.
« Last Edit: October 05, 2013, 04:24:58 PM by SPARKY »
« Reply #1412 on: October 05, 2013, 11:07:32 PM »
Did get back  about 3 hours of tedious wiring and routing of wires  the eng is now done dash gauges  and GV excepted.
« Reply #1413 on: October 06, 2013, 03:10:35 AM »
Great progress there. You guys must be really enjoying yourselves on this. It shows.  :cheers:
« Reply #1414 on: October 06, 2013, 08:55:08 AM »
Several reinforcing moments coming up soon:
Firing it and running the all the systems
Loading it on the trailer for its first inspection and race
Passing inspection
Pulling up to the start line with its first (controlled) pass and the chute coming out
Others to (HOPEFULLY) come:
 first all out pass
 and maybe getting to go visit the MAYOR :-D
  • After further investigation, I/GT record holder
« Reply #1415 on: October 06, 2013, 10:59:26 AM »
I must confess - I've let my reading on this one move to the back burner.
Then I called Sparky yesterday, and we chatted for a while, but he had to cut me short and get back to work on the car - Respectful of Andy's time and conscious of how those minutes can slip away.
This thing is turning into one very scary, no compromise, no bullshirt tank.
Carry on, Spark-o!  :cheers:
« Reply #1416 on: October 06, 2013, 12:19:30 PM »
MM  thanks for the kind words ---BUT I beg to differ--- its all about compromise---TB and I have chatted, emailed and talked on the phone about the compros  many times you balance the trade offs ease of building vs safety, ease of building vs aero, ---packaging packaging packaging---TB said this lakester is just an education preparing for a streamliner---I sure hope not.  LOL
« Last Edit: October 06, 2013, 02:56:09 PM by SPARKY »
« Reply #1417 on: October 06, 2013, 12:44:25 PM »
It's time for Three Bills Bill to do the bizzo again, go mate, were all cheering you on  :cheers: :cheers: :cheers:
« Reply #1418 on: October 06, 2013, 06:48:09 PM »
Tim Cox dropped a MSD plug wire tool off so that I can make up my 4.5" coil wire.  We partook and discussed getting our cars done for El Mo---him for Oct. and me for Nov.
Offline 38flattie
« Reply #1419 on: October 06, 2013, 06:56:22 PM »
It's looking good, Sparky! I can't wait to see it again! :cheers:
http://youtu.be/89rVb497_4c
« Reply #1420 on: October 06, 2013, 07:56:37 PM »
Thanks guys
John came over today and we got the frt axle back in should be able to nail it down and a start aligning the wheels.  Then we started on the canopy---lots of clean up and fitment needed form all the "trama" its been through the HD gas struts have deformed the instrument panel . we will have to massage this thing to function :-o
« Reply #1421 on: October 07, 2013, 02:13:28 PM »
Wow  this comes under the heading of slot me now (when its built) or slot me when you are going over things for the umteeeenth time to check alignment or binding as i was checking the tranny mount---guess what its cocked so I will have to slot the cushion mount  hole or just drill the hole larger and use a heavy washer.  :-(
« Reply #1422 on: October 07, 2013, 11:44:08 PM »
Tranny mount slotted and shimmed to the point that I am as happy as I hope Miss Liberty is going to be!!!!!!!!!!!  lots of ground wires done today---usually they are what will give one problems---so lots of time GROUNDING :-D
« Reply #1423 on: October 08, 2013, 04:21:09 PM »
Made up the solder end battery cables and wired the cut off switch  if I were to connect the battery everything but the panel gauges would work.  tedium tedium but slowly getting there.
Offline Frankie7799
« Reply #1424 on: October 08, 2013, 04:47:41 PM »
Keep at it, you'll get there. Are you going to make a new instrument panel out of thicker material?
