Author Topic: MS LIBERTY a Wild Weasel's belly tank  (Read 613170 times)
Re: Wild Weasel a TRUE belly tanker
« Reply #1380 on: September 29, 2013, 12:48:14 PM »
Thank you Sir Jim --- will have one before the day is over  :-)
Miss LIBERTY,  changing TKI  to noise, dust and RUST!!!
   Center for Self Governance            tncsg.org     mrspowell.org
« Reply #1381 on: September 30, 2013, 12:23:43 AM »
Well I did not get over to the Devils Workshop better known as "Harbor Freight" but I didn't sleep at the Holiday Inn either!!!!!!!!!!
But I did have an on again off again day in the shop getting a lot of small things DONE!!!!!!
I should be able to put water in the eng. systems tomorrow-- and maybe the oil system also---Marty came by tonight and we worked on "nailing down" the shifter system to getting the slack out of it, so that you can get it in the right gear with out thinking about it!!  :?
Offline Frankie7799
« Reply #1382 on: September 30, 2013, 01:00:12 AM »
Maybe Tuesday we can put some fire in the pipes
Online WOODY@DDLLC
« Reply #1383 on: September 30, 2013, 07:11:47 AM »
Youse guys are starting to scare us!  :-D
« Reply #1384 on: September 30, 2013, 07:22:51 AM »
Woke up---couldn't get back to sleep  went to the shop---started pouring water---lose fitting here lose fitting there got it down to one cold weeper---I tapped a hose barb connection to deep and I am going to have to drain a pull it out and use pipe thread sealant instead of  tape.  Also poured in two gallons of oil will have to go get the angle drive to prime the eng. oiling system.
« Reply #1385 on: September 30, 2013, 08:10:15 AM »
Bill, think about getting an angle drill instead of an angle drive adapter.  It will be a lot handier in the long run.
Keep up the good work.  :cheers:
« Reply #1386 on: September 30, 2013, 09:21:41 AM »
Sparky,, Stainless is  right on the angle drill, Home Depot or Lowes have them and you would be supprised how often you will us it. I have one Roybe and two air 90 deg. drills. I have two 90 deg. adapters as well and a pain to use in most cases. Keep up on the build and keep us posted. :cheers:
« Reply #1387 on: September 30, 2013, 09:26:33 AM »
I'll second or third that also.  I've only primed small blocks with the distributor out and it takes a lot of power from a good higher power drill as you know.  I wonder if that HF adapter is up to it?
Congrats on all you guys are getting done,
« Reply #1388 on: September 30, 2013, 12:47:28 PM »
Thanks for the input guys---I will go to HD and check out their Rigid and down to "ole 5 time"  (MR 6 TIME  want-a-be)  place and check out his KOBALTs.
« Reply #1389 on: September 30, 2013, 03:51:34 PM »
Here Bill, found yer angle drilll........
« Reply #1390 on: September 30, 2013, 05:46:00 PM »
LOL
checked out the battery powered angle drills at HD & Lowes--- all these guys had was 3/8" chuck--- I thought them too wimpy---I ended up buying a DeWalt 90 deg adapter.   After all and  made a VERY  ROOKIE mistake --   :-o   of not rechecking ALL fittings again----resulted in about a quart and a 1/2 on the floor from 3 not tight enough and 1 vent plug--- I left completely off in my excitement to see how it works.  My 18V Rigid works fine but a battery does not last very long under constant load.  :-)
Offline Captthundarr
  • In line
« Reply #1391 on: October 01, 2013, 07:12:01 PM »
My rigid don't last long any more either. :roll:
Offline joea
« Reply #1392 on: October 01, 2013, 07:32:24 PM »
'''My... Rigid works fine but ...does not last very long under constant load..."...
"My rigid don't last long any more either"....
Goggles bent drill pic.....
geeze guys....may need a new sponsor..pill or something...
whatever..."keep it up" we want to see you get the job done...
« Reply #1393 on: October 02, 2013, 12:25:55 AM »
Toward the end that you guys are trying to take this:
The name of this entry will be FPD  Racing
 female pleasure device   We are going to contact all of the battery manuf. about sponsship---with first right of refusal going to the "Enegerizer Bunny"
EverReady second, and Duracell last choice  there will be two batteries in the paint scheme.
« Reply #1394 on: October 02, 2013, 01:43:34 AM »
Got lots done today!  I finished the fuel shut off system & several other small little things.  We are getting closer and closer to the real deal.  Need to   put brake fluid and bleed the system.  Will go through the fuel system and cut the final bolts to hold down the air scoop.
