For the brake side, the original rotor was small and I couldn't find a caliper that would fit between my frame rails and grab the rotor. I wanted the caliper ahead of the wheel so I could remove the rear wheel without removing the caliper. And with the caliper rearward, I was worried about clearance to the fairing.
Another trip to the salvage yard and I came up with a gigantic disc in good shape and it was flat and not dished. Again with Doug's help (or more like Doug with my help) we made an adapter to fit the Honda wheel and accept the new rotor. I still had clearance problems with the frame but managed to just fit a Kawasaki caliper into the slot. I don't have much fore and aft movement but the 35 tooth is installed and I should be able to fit a 34 or 36 if needed. Now I have to find a front master cylinder with a remote reservoir as my handlebars are nearly vertical. Any suggestions?
Rear view shows how tight everything is with the narrow frame.
Incidentally, at 7000 rpm with the 36 tooth, I should have been at 153 mph but I guess I was closer to 6800 rpm. With the 35 tooth, I should be at 158 mph at 7000; with the 34 tooth, 162. Unfortunately, I'll need about 15 more hp to get there and I have no more ideas (almost none at this point) to get there, so good salt conditions, fair winds, and following seas may be required!
