Looking into the future of supercharging has me doubting the use of a draw thru system with a carburetor on the single cylinder motor, due to problems with fuel dropping out of suspension and inefficiency due to heat build-up and no real possibility for aftercooling. Looking at a blow thru system with a carburetor also has some fueling issues, which may be easier with fuel injection. To get to that point, I have decided to start by adding some data logging to my current motor, which will be 100cc larger with a higher C.R. for this year, so will probably run hotter.
The Megasquirt system is real interesting because I would be able to customize my ignition as well as fueling, and get feedback from each run on a laptop to make appropriate adjustments. Adding fuel injection in the future would then be much easier. Not being a computer geek, I would need help, but my pit man, NSF Ed has experience with re-mapping and my daughter is an electrical engineer. But what I'm not clear on with the M.S. system is how to get on board viewing of what's going on before she goes bang as opposed to after. There's an excellent build diary by MXRob on ThumperTalk on the conversion of a Suzuki DR650 to fuel injection, but he mounts a small laptop on the bike and just makes dozens of runs around town and stops and makes adjustments as required (a lot of them). That might be difficult at Bonneville. So although the purchase of a Megasquirt system makes sense, even without the fuel injection, the question is how to have active gauges indicating AFR and Cylinder Head or Exhaust Temperature along with the controller/data logging function?
As a cheaper alternative for this year, the Innovate MTX-L AFR display can be piggybacked to a EG or CH temperature gauge, an RPM shift light (which is also a MAP gauge, not needed at this time) and connected to a data logger. Total price for the three gauges and the pocket data logger, about $600. Of course, I would also need a PC, as my Mac Laptop is not compatible (without the conversion to Windows). I already have a good Scitsu tach as well as a narrow band AFR, CHT, and Oil pressure gauge, but they are cheapies not capable of data logging that I know of.
Any suggestions would be appreciated.
