The short answer is no. I can change it, but I have to remove the outer timing cover, the inner timing cover, including pulling a pin to allow cover to be removed over transmission shafts, removing the timing trigger which is on a taper with no key, removing the crank pinion nut, and rotating the pinion gear to one of 5 positions (with a selection of 3 offset keys), then reassembling the lot (no gaskets on cases except RTV silicone, so lots of cleaning), torquing the pinion nut, assuring that a seal and an o-ring that feed oil to the crank are not disturbed, and resetting the timing. Worst of all, the only way to know what you got is to degree the cam timing after these changes. I will be doing so this winter to find out if something has changed and I will catalogue the 5 positions for future reference. In any case, I wouldn't be able to do it during a dyno session unless I wanted to buy the dyno!
This is why I'm curious to know what the cam timing is for Nascar or high performance Hemi motors running at Bonneville as a starting point. My cam was designed for road racing standard long stroke B-50s and not for maximum hp.
