The effect of a rear wing at speed is to counter any body lift and maintain the CG.
I dunno about
maintainbut I can see your point about countering the lift characteristics of a given body shape , it's a compromise.
So. Landspeed is a trading game, valuable assetts include power, reliability, traction, weight distribution and streamlining.Liabilities include drag, low power poor weight distribution and lift amongst other things.
A wing uses airflow to create downforce, thus increasing the "apparent" weight on the rear of the car/bike.
Using the arrow analogy we need the Centre of Gravity to be ahead of the Centre of Pressure or the tail will want to pass the front.
As the speed increases the wing begins to produce downforce , shifting the
dynamicCoG rearwards....If the wing maintains the relationship between CoG and CoP by significantly adding to the
drag at the very rear of the vehicle it will remain stable , but at the added expense of the additional drag......this can be compensated for by increasing the power............this may introduce it's own problems with traction.....
However if the drag created by the wing does not maintain the CoP/CoG relationship then the limiting factor may well be the aero-stability.....
I'm being careful not to tread on any sacred ground here but the bottom line is drag , the less you have , the faster you'll go............
....................... brains and brawn, David and Goliath................
It's the SOS, but the same questions keep getting asked.......
The real questions are who's gone 100/100.......200/200.....300/300
