Doc- my car makes same power (235 at wheels) at similar RPM (9600), not much low end torque. Though I made two changes in 09, cold air intake added, and took off the factory stock spoiler/wing off got me 6 mph. 2 liter NA engine pushing a 87 Firebird (went 170+). The cold air helped some but I saw a change at Maxton before Bonneville that proved the wing was part of that 6mph. Until you have a traction problem, run without the wing. Any lift or down force it generates causes drag and you will go slower( and if it lifts might go sideways more than you like. When you have power that exceeds traction/aero drag (and therefore have wheel spin) and therefore are likely to spinout; you will go faster without. Adding weight helps the mechanical traction but does cause slight increase in rolling resistance and therefore drag but is much smaller than the aero penalty of wings and things. However, until you go over 175 in the quarter ( the 2.25 mile timing trap) you are still, especially with a small engine car, in a bit of a drag race so acceleration is affected by weight and is therefore also a small penalty. You want gears/power/aero etc to all be pretty much peaked when you pass the 2mile marker so you accelerate very slowly mph or two over the mile. If you are not peaking until later you won't reach your maximum speed. When you get to bigger numbers, wings, spoilers, side plates and weight all may be needed to keep you pointed right way and not overpowering the tires. Weight in the a$$ end of the car is not nice from an aero stability stand point but as long as you keep it pointed right way is fine. There are threads here about this. Lots of opinions. You start somewhere and work up to it. I'd start no wing and see how you do. Might fall in love with salt flat racing and be hooked like all of us here. Might say not your cup of tea and only go once in which case $$$ on spoiler is wasted. Besides you have huge work to do to turn your track car into and LSR car to start with. Sorry to tell you, bet many $$$ your cage is not legal. (it's .093 wall isn't it?)
