The APR was developed with mazdaspeed also known as mazda motor sports. APR builds it Mazda designed it. All three that I showed later on were avialble from dealership. The mazdaspeed wing was altered to the GT 300 APR Contour wing. Through mazda motor sports. I know they sold well over 500 of them. It helps my car a great amount. Improved speed and track times immensely. I can hold corners at 10-15mph faster, and I can get upto speed about 150 yards faster on some tracks. I am putting just a little bit over stock to the ground at 235HP, its a rotary so torque is very low, but at 9800 RPM who cares:P
My setup is rated as 2nd best setup on a car under 100,000 dollars. Its a 50/50 weight ratio, but I do have a problem with the steering. Its too loose at 16.6:1, I am still working on a way to run a 14.6:1. The steering is an electric steering box with a cpu controlling it at different speeds. I have tighter sway bars front and rear, I also have front and rear strut bars. All of which are stock. Mazda designed the rear sway bar to hold the spare tire. It came factory. The front strut bar also came factory under the engine cover. The sway bars are the R3 mazda speed where they changed the spring rates to increase performance. Everything I have is stock factory though. Nothing is aftermarket or not an option that wasnt dealer offered.
Yes thats the rattlesnake raceway you are thinking of.
