I would like to put a disclaimer on Mikes post. There is no recommended tire pressure for LSRing on Drag Radials. We run the pressure we do because it has worked for us. You need to determine what pressure works for you. I don't think there is a MFG out there that will recomend their drag radial for long distance high speed runs. The Mickey is the drag Radial of choice for almost all the really fast cars. If you walk around the pits you'll see that. The size and pressure is something you'll have to figure out on your own. As I've learned from more seasoned veterans side wall flex is not your friend due to heat buildup, so think lower profile. We also replace them every season or every 10 or so passes before they start to show any signs of real wear. $150 a tire is cheaper than an MRI, CT, or a funeral. Your results may vary.
