Author Topic: Spirit of South Dakota Lakester  (Read 304593 times)
Re: Spirit of South Dakota Lakester
« Reply #435 on: March 28, 2013, 03:00:39 PM »
Well, thanks to Skip,Steve and Rex I have the parts and knowledge to start on my ice water tank. Picked up parts for the spray bar, my Rule pump, Intercooler and Rad. Tommorw get the sheet aluminum and will take lots of shots for all to see.
I am planning on a shoe box style lid held down with spring retainers like these
https://www.pegasusautoracing.com/productdetails.asp?RecID=756
or these
https://www.pegasusautoracing.com/productdetails.asp?RecID=770
Any ideas on hole sizes in my spraybar (PVC tube)?
« Reply #436 on: March 28, 2013, 08:07:01 PM »
T-Man;
It probably isn't important in your application, but the rubber latches do not rattle.
« Reply #437 on: March 28, 2013, 08:31:06 PM »
Metal latches are fire proof.
« Reply #438 on: March 28, 2013, 08:59:33 PM »
That was my thought as well Glen, plus the spring ones will provide some venting from burst should I pop the radiator. The lid will be padded from the lower box to keep it from rattling.
« Reply #439 on: March 28, 2013, 09:01:57 PM »
Good point, Glen....but if the rubber latches burn off, the tank dumps water into the cockpit. I wouldn't be too worried about that. :-)
« Reply #440 on: March 28, 2013, 09:09:43 PM »
Yeah, but a water soaked fire suit is a steam bath you don't want. Thay can as do absorb water.
« Reply #441 on: March 28, 2013, 09:57:08 PM »
All good points! But, this tank is 4 feet behind me, with the engine and the turbo between us. The tranny is below it and the fuel behind.
« Reply #442 on: March 28, 2013, 10:16:41 PM »
Not to mention the sealed firewall  :cheers:
« Reply #443 on: March 28, 2013, 10:20:25 PM »
Fire has no path, it flames everywhere, small holes become blow torches, Trent you remember the pictures I sent, lessons learned. We all fear fire as at speed it's hard to manage until you get stopped and get assistance.
« Reply #444 on: March 29, 2013, 01:40:03 AM »
Glen, pardon the reference but yes, I do remember those pictures! They are seared into my brain. Scary stuff. That is why the fuel and the rad/intercooler have an inline 6 between me and them!
Thanks for all the input so far guys! :cheers:
« Reply #445 on: March 29, 2013, 11:49:17 AM »
You're right, Glen-- I forgot about that.
Regards, Neil
Offline 38flattie
« Reply #446 on: March 29, 2013, 06:41:34 PM »
Trent, I have a question:
I built a rad in a tank, but submerged the whole radiator, instead of using a pump and spray bar. The heat absorption is awesome!
What is the advantage of the pump and spray bar in this setup?
http://youtu.be/89rVb497_4c
« Reply #447 on: March 29, 2013, 08:13:56 PM »
I will let Skip answer that one over on the HAMB where you asked. But, what I am doing is the same as you but the intercooler is in the same tank so the spraybar will be aimed at the intercooler. My rad is at teh bottom and the intercooler is stacked on it so the top is exposed.
Offline 38flattie
« Reply #448 on: March 29, 2013, 08:43:28 PM »
So it's the 'radiator' part of your intercooler? Could you put the intercooler beside the radiator, and save yourself the extra effort of the pump and spray bar?
« Reply #449 on: March 30, 2013, 11:25:54 AM »
Due to space I am packaging them together. I don't think I would even need the spraybar but it will keep the water moving in the tank as the ice melts. Besides, it was a quick $30 and easy to do. Cheap insurance if we need it in my small tank.
