Craig's List find I found a 95 Extended cab SWB 4x4 roller I am going to look at today it is hit in the passenger side but the frame is supposed to be straight. This will give me a factory frame with 4 wheel drive, there should be less debate as to origin.
Nathan, look up NP203 transfer case---Ford, Dodge and GM all had 1/2, 3/4, and 1 Ton trucks that had Full Time 4x4 trucks with all kinds of eng and trans in the 70's .
they had
4 Low Lock
4 Low
N
4 High
4 High Lock
NO 2 wheel drive position
Update: 2/2/2015
There is a difference between Full Time Four Wheel Drive and AWD All Wheel Drive and is usually in the transfer case.
MOD Pickup Truck rules say Full time Four wheel drive:
Full Time Four Wheel Drive may or may not have an inter-axel diff. but 50% of the power is available to each axel.---usually not the case with AWD
